Thread: Auto-Fill Plumbing - Avoiding stagnant water and other Q's
    Hi There,
    I am considering purchasing the Levolor K1100 auto fill system, and have questions regarding the installation. From reading the manual I understand that there are two basic install methods:
    1.)Using a static standpipe into which a sensor sits vertically, or
    2.)Using a “remote” sensor mounted onto the inside of a skimmer.
    I am leaning towards the second option because I feel that having a static pipe without much water flow and exposure to fresh sanitizer is going to potentially become a “breeding ground” for undesirable things. In my installation the pipe would be 20-25’ long over to the equipment pad, and I would expect nearly zero water flow in the pipe except for some wave action...
    If the second method is used, how does the sensor typically get into the skimmer? Do you run a separate conduit into the skimmer body and then seal it somehow? How would one seal this fitting? Also, how is the sensor bonded to meet electrical code as it becomes a metallic object within the water zone?
    Maybe I would be better off with a "typical" auto-fill system? I've read on a couple of posts that you can connect the auto-fill unit to an unused skimmer port - How much does the water level in a skimmer change when the pump is actually drawing from it (I know there are many variables - but imagine 2 skimmers on an 18x36 with a 1.5hp pump). Would the water level in the skimmer drop by say 1/2"? Then the Autofill would try and compensate for this... I guess this might be OK, because when the pump cycles off, the level will rise slightly higher than it originally was (~1/2") - and this shouldn't be an issue - right??
    Again, would there would be very little "flow" in this pipe that connects the autofill to the skimmer, although it could be much shorter (AKA a breeding ground for algae and bacteria)?
    Thanks for your input...
    Thanks - John
    Assembly stage of:
    18x36 DIY IG - SWG - Pro-Logic P4 - Hayward Universal 12V LED - ClearDeck Inground Solar Cover System - 2 Skimmers, 5 Returns + 2 Step Returns - 400BTU Hayward NG Heater - 1.5HP Hayward TriStar 2sp Pump - 30" Hayward Sand Filter - 280sq/ft Enersol Solar Heating - Solid Safety Cover with mesh drains - 30mil TideWater Liner - - TF100 - 20'x30' Pool House/Dog House :)
    New Lowell, Ontario, Canada.
    38,251
    Re: Auto-Fill Plumbing - Avoiding stagnant water and other Q
    I have just had the typical auto-fills. In the first pool it was added with the pool and was only 1 foot from the pool. In my current pool, I added it when resurfacing (drilled a new hole in the pool) and had to extend the pipe just past the concrete deck, so it is about 5 feet from the pool ... why would it be run all the way back to the pad?
    I do see you point though as the water in the auto-fill bucket does not really move and wonder what should be done to avoid anything growing in there ... since there is 0 FC in that bucket.
    The "run back to the pad" would be required only if the K1100 was used as in method #1. They have a sensor that sits in a vertical piece of pipe that is equalized with the pool level. You wouldn't want this pipe sticking up though the deck - So I assume it would run back to the pad, or somewhere inconspicuous...
    How difficult could it be while under construction to tap off of a return line going to the pool, and add a 1/4" line which feeds into the auto-fill bucket? Or something along those lines with a valve that could throttle back flow to prevent splashing in the bucket... This could present fresh chlorine to the autofill.... Hmmmm....
    Anyone see any issues with this?
    Am I wasting my time on a "non-issue" in the bigger picture?
    Assembly stage of:
    38,251
    I would just have them add a hole in the pool to a typical auto-fill bucket. They just use a float valve like in evap coolers or toilets. But, that is all I have ever see or used.
    I do not know the advantages of the electronic setups. And have not heard of tying the auto-fill into the skimmer bucket.
    AH. I had to re-read your idea about the return line ... that is an interesting thought to get some chlorine in the bucket. Of course I wonder if you could just put a 1" tablet (or less) into the autofill if the algae became a problem.
    There are likely more important things to worry about when planning an entire pool
    I recommend against adding chlorine to the auto-fill chamber. I tried it and it disintegrated the toilet-type valve. My chamber also acts as an overflow so it gets flushed (unavoidable pun) pretty frequently with the amount of rain we get in south Louisiana. Just my $.02.
    Trae - 16x33 Inground, Pentair (TR100C, IntelliBrite 5g, Whisperflo WFDS-26), Hayward Goldline Salt System with T-Cell-15, Polaris 280 Black Max
    May 2012
    Montville NJ
    545
    My gut feeling is that if you put in a standpipe, and covered the end that is open to the air with a filter (I am thinking cut a plug out of some open cell foam - like a small engine air cleaner. Then you would be ok just pulling out the plug and dumping a cup or two of bleach down there every so often. The water in the pipe is going to have no sunlight on it, and as you said is not going to mix with the pool, so it should hold its FC level for quite some time.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
