Thread: To lower my TA or not? (I have a SWG)
    Sep 2010
    Orange County, CA
    52
    The (SWG water balance article) recommends keeping TA at 60-80 (and says this is IMPORTANT). The article on (how to lower your TA) suggests that lowering your TA is only important in the following circumstances:
    • -because you want to slow down the rate that the PH rises
      -if high TA is contributing to a high calcium saturation index (CSI) which puts you at risk of calcium scaling
    So if my TA is around 90-110*, is it important to lower it? I'm guessing the reason for the recommendation is that high TA can lead to high pH which can get CSI out of whack and lead to scaling, which affects the SWG as well as my pool finish. I have an automatic pH system on my pool which works really well, so I don't get high pH.
    Are there other things about SWG that would make them work better with lower TA? I don't want to go to the hassle of lowering it if I'm solving the situation through the acid feeder/pH system. But, if there are other reasons, then maybe it's worth it.
    *90-110: I get different results from my test kit than when I take it to the pool store. I'm not sure who to believe.
    Southern CA 30K gal Pebble Pentair WhisperFlo 1HP 2 speed Hayward DE6020 filter Paramount Debris Canister Goldline/Hayward AquaRite Pro SWG (T-CELL 15) Sense & Dispense (acid) Pentair IntelliBrite 5G and GloBrite Inter-Fab G-Force slide Jandy deck jets Lion head spout Dolphin Premier Cleaner Taylor K-2006 test kit
    38,254
    Re: To lower my TA or not? (I have a SWG)
    High TA causes the pH to rise. SWG also cause the pH to rise. The lower TA will just slow down how quickly the pH rises.
    If you are happy with your pH, then do not worry about the TA. The TA will lower a little every time you lower the pH with acid, so not really no need to focus on the TA.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Red
    Trust your results over the pool stores. Even if yours are slightly off, they should be much more consistent...and you will adjust as your pool demands it (i.e. high TA will require more frequent use of MA, therefore lowering the TA level over time).
