Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: is Borax the same as Pool Conditioner
    U.S.A. - California
    32
    [Mod (linen) edit: Poll removed, since it was confusing with the thread title:
    The questions was:
    Do you use substitutes products for your pool like clorox and borax?
    There were 10 votes yes and 1 vote no at time of removal.]
    Hi. this is my second Post.
    I have a Summer Scape pool (specs on the bottom) The little pump that comes with the pool just died. So I got myself a SanPro 50.
    After having the pool completely green! and infested with algae (since I went without filter for like 5 days) I ran the new sand filter the whole night and the algae was gone. I add a whole gallon of chlorine and brush the bottom of the pool. the Algae is dead! Thank God!
    BEFORE
    [attachment=2:2so0i0j6]green.png[/attachment:2so0i0j6]
    AFTER
    on this fist photo you can see a little bit of green at the bottom I will brush that too.
    [attachment=1:2so0i0j6]photo 1-1.jpeg[/attachment:2so0i0j6]
    [attachment=0:2so0i0j6]photo 2.jpeg[/attachment:2so0i0j6]
    So, I know that for now on I have to keep the levels of Chlorine in check and run the pump.
    MY REAL QUESTION IS
    I took an example of my water to the local pool store. The guy said "you chlorine is a little bit to high, you need conditioner"
    I have BORAX. Does Borax has the same effect as conditioner? I read at POOL SCHOOL that BORAX is like "water conditioner"
    He recommended 2 pounds of that stuff. So, All I need is 2 pounds of BOREX?
    I am so sorry that I dont have a testing kit, but after buying the pool, filling with the water and installing the MANDATORY fence, the sand filter, and all the chemicals, I dont want to spend more for a while.
    Thank you for reading!.
    Pool: 5725 gallons
    Filter: SandPro 50 half horse power
    Type Pool: Above Ground Summer Scape
    Made out off: I dont know what type of material is made out off.
    Size pump and flow rate: Half horse power / I dont know the flow rate
    Date of pool intall: June 20th, 2012
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: is Borax the same as Pool Conditioner
    As far as I know - there is no accepted generic definition of what "pool conditioner" is - I think they just wanted to sell you something.
    As for the testing - a minimal test from Wally World (6 way) is better than nothing.
    22,550
    Conditioner is usually CYA. It can be other things but it normally refers to CYA. Conditioner and stabilizer are usually the common terms for it. It is definitely not Borax!
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    I second Bama's nomination. 98.3% of the time conditioner means CYA. Also did you know 64% of statistics are made up on the spot? Seriously though, conditioner in my experience refers to CYA.
    U.S.A. - California
    32
    ok. So correct me if I am wrong.
    Borax is the same ??????????????
    Conditioner is CYA
    At pool school the BBB method does not mention CYA what is that? Do I have to get it from the Pool Store of is there a substitute?
    Pool: 5725 gallons
    U.S.A. - California
    32
    Never mind, this post: http://www.troublefreepool.com/do-i-...ore-t8256.html says there is not substitues. I will ge the little kit and post some results. How about that?
    Thanks!
    Pool: 5725 gallons
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by denisrenepl
    Read the Recommended Chemicals section. CYA is listed.
    U.S.A. - California
    32
    It sounds really serious. If I dont add that what kind of effects will I have in the Pool?
    ALSO the guy from the store told me to add this http://www.hasapool.com/prod-type/no...nditioner.html
    it is CYA. He told to add all the bottle. I guess I will go pick it up.
    What do you think?
    Sorry if my questions are stupid but I NEVER in my life had a pool
    Pool: 5725 gallons
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Have you used any of the bagged chlorine products or "pucks"? If so, you may already have some CYA in there. How long have you had your pool, and what size is it?
    38,303
    Do NOT add the whole bottle until you know what your current CYA level is (as PAGirl asked ... have you used any solid chlorine?).
    Once your CYA is too high, the only way to lower it is by replacing water.
    So you know, 1 lb of the granule CYA will raise your CYA by ~20ppm (use poolcalculator.com to make these calculations) ... do not just dump it in the pool as the bottle may say, put it in a sock hung in front of a return.
    U.S.A. - California
    32
    The only chlorine I used is liquid. I added a Clearview when the pool was green.
    www.hydropool.com/cgi-bin/hydro/item/Po ... DB001.html
    I also used some Pool Aid stuff (www.intheswim.com/Pool-Chemicals/Natura ... First-Aid/ )
    I won't add anything until I get a test kit. For right now I will take an example every morning to my local store pool. At least they can tell me if the chlorine is low.
    Can I go in the pool now???????
    Pool: 5725 gallons
    U.S.A. - California
    32
    If the chlorine is ok, can I go in now? The algae is gone. And my pump is working....
    May I?
    Pool: 5725 gallons
    U.S.A. - California
    32
    Quote Originally Posted by PAGirl
    The chlorine I used is always liquid. I did added a Clear view shock when the pool was green, and a First Aid Pool.
    Read my signature. All the info you are asking is there
    Pool: 5725 gallons
    38,303
    If you have some FC in the pool, and the water is clear and you do not have high CC ... you are free to use the pool.
    That Clearview is dichlor so it added CYA ... how much did you use so that you can estimate how much CYA you should now have?
    Just know that if the CYA is very low, the sun is going to break down the FC quickly. You could add the CYA in a sock and go swimming and give it a squeeze every time you swim by to help it dissolve.
    EDIT: Just want to point out that some of us use our phones to access the forum (using Tapatalk), when I do that, I can not see people's signatures without opening your profile. Might explain the previous questions.
    U.S.A. - California
    32
    I added the whole bag from the link I posted before. The guy from the store told me my chlorine was a little high.
    I do not want to add the CYA until I get a a test kit.
    The cya helps the FC to NOT break,right? so I think I will just add chlorine at the end of the day.
    What is CC level?? O_O
    Pool: 5725 gallons
    38,303
    Read:
    ABC's of Pool Water Chemistry
    Recommended Pool Chemicals
    Using poolcalculator ... 1 lb of dichlor add 12ppm FC and 11ppm CYA. Note that the CYA test only goes down to 20ppm.
    I would recommend adding a pound of the granule CYA which should put you around 30ppm and actually be measurable when you get your kit. It will also greatly reduce the amount of FC you have to add each day as you will loose less to the sun.
    I feel the need to give my opinion on the poll's wording. When I think of substitute - it makes me think alternative, meaning similar... it works the same, but it's different than the original. Sodium hypochlorite (salt-water-chlorine mixture) is the exact same liquid whether it's labeled Clorox (6%), "Pool Shock" at 12.5% or Pool Sanitizer (10%). Many other chemicals are the same, look at active ingredients and you will find what the pool store sells is the exact same stuff, with additives thrown in (which means extra chemicals you likely don't need!).
    The only chemicals I've used this year are:
    sodium hypochlorite (currently using 12.5% labeled "pool shock")
    muriatic acid (liquid form, but the exact same active ingredient found in pH minus or Alkalinity minus)
    and possibly before the season is over, a bit of sodium bicarbonate to raise alkalinity. Commonly known as baking soda and sold by the pool store as Alkalinity Plus for 13-20x the price of Arm & Hammer)
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    U.S.A. - California
    32
    Quote Originally Posted by Speedo
    I am sorry I failed to see the point on your response... maybe I am missing something.
    Pool: 5725 gallons
    Jun 2012
    Mint Hill, NC
    2,589
    He is saying these "subs" are really often the same chemicals packaged differently not different at all as the poll implies.
  20. Back To Top    #20
    U.S.A. - California
    32
    Quote Originally Posted by UnderWaterVanya
    Oh I see the point Borax is not a "sub" But is the same thing BUT from a different source!
    I get it. Thanks!
    Pool: 5725 gallons
