Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: New build Fort Worth TX
    New to this but, here are some pics of the progress.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New build Fort Worth TX
    Welcome to tfp, thebenz
    Looking forward to your project!
    Thanks for the welcome. This is a pretty cool website.
    more progress...
    more progress...
    still more progress
    tile and coping still
    dot dot dot...
    wait wait wait
    Deck poured hopefully this friday. Not sure what comes after that since all plumbing and electrical are done--to my knowledge. Also, at this point in the build we are exactly 14 days in since the start.
    I've done a little searching on here but didn't find too much. Does anyone have a suggestion on how to keep grass out of the pool pump area? Was thinking of putting crushed stone around that area on top of weed barrier but, not sure how well that will work??
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,428
    ROUND UP! I mix it VERY heavy on the round up side instead of the water side!
    We have a GOOD (do NOT go cheap on this) weed block with white marble over it. I spray STRONG Round Up over the whole area once a month to make sure it never becomes a problem.
    Your pool is going great!
    Do you have your pool test kit yet? Go ahead and order it now so it will be there for when you add water! In fact you can go ahead and test your fill water now if you are filling with a hose.
    Kim
    I think my pool company gives us a test kit, will check on that one. thanks for the info.
    22,543
    They give you a test kit, but it's not worth having.
    You'll be much better off to go ahead and order the TF-100 now and learn to use it on your fill or tap water. That way you'll be ahead of the game when the time comes.
    Quote Originally Posted by thebenz
    Who's your PB?
    I'm two months into my new pool in NW Fort Worth, and the smartest move I have made so far was to purchase the TF100 test kit. You won't regret it.
    25k gallon inground plaster with hayward pumps, waterfall, beach entry with 2 bubblers, deep-water seating bowl, diving board and attached spa with heater and blower = Heaven on Earth!
    Ok cool. I'm using Klapprodt Pools. I'll order one and trust you guys! I'm putting in a saltwater pool, is the TF100 what I need for that?
    deck set today
  20. Back To Top    #20
    deck set
