Thread: Borates
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Borates
    Just took the plunge and added 7 boxes of the Mule and 2 gallons of acid... now the 48 hour wait to test (that's only the borate test, right?). Should I test pH and FC now to make sure it's still close?
    Stupid question, now that I'm at work and thinking about it. I have an Intermatic Timer. I removed the start stop posts so it would run 48 hours, I could have just flipped the lever to the right to bypass those... right?
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Apr 2012
    SW Ohio
    456
    Re: Borates
    you should go ahead and test the fc and ph and keep them in range and then 48 hours after adding borax test it, i don't know about the timer issue but i'm sure someone willbe around shortly to answer that question........Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    38,274
    Re: Borates
    RE: timer ... you needed to remove the stop trips or the timer would have turned off. The lever actually moves due to the trips ... and you will find that you can not manually flip the lever is one of the trips is currently engaged at that time.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Re: Borates
    Thanks. I just wasn't sure if the on trip gets bypassed each round so I removed them all (have 2 cycles). I'm amazed that my fc is still above 5 after shocking to 18 ten days ago. Did have to add a bit more MA.
    DIY chlorine feed
    BBB
