Results 1 to 12 of 12
Thread: Adding cyanuric acid questions.
    We need to add cyanuric acid to our new pool. Do we turn off SWG before, why, how long? Also removing solar cover, how long? When is is safe to swim?
    Doug
    12' x 24' IGP, 7700 gal, Jandy Aqualink PDA, Jandy LRZ 2500,000, Jandy CL 340 filter, 1hp Jandy Stealth pump, Jandy Aquapure SWG.
    38,397
    Re: Adding cyanuric acid questions.
    Are you adding the granules or the liquid? In either case you should not have to turn off the SWG as long as you do not add it to the skimmer (which we recommend you never put any chemicals into the skimmer).
    I do not understand the question regarding the cover.
    The pool is safe to swim when FC > the minimum and < the shock level for your CYA level (See Chlorine CYA Chart), the bottom is visible, your CC is not more than 0.5ppm, and ideally your pH is in range for comfort.
    Apr 2012
    SW Ohio
    456
    you can leave the cover on when you add cya just put it into a sock and hang it in front of the return just don't let it touch the liner because it can discolor it, also you can swim safely with it in the pool as a matter of fact knead the sock as often as you like it will help it dissolve faster........Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Acid went in skimmer, SWG was on for 20 minutes, she read instructions on container before I got home. Will see what happens.
    Thanks
    Apr 2012
    SW Ohio
    456
    Don't backwash the filter for a couple days because if you do it will wash a bunch of it out.... You should never add any chemicles to the skimmer......Mike
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by fast1971chevelle
    There are a few exceptions DE is one of those. Generally it is good to avoid adding highly acidic or highly basic corrosive chemicals to the skimmer. So no chlorine, acid, etc.
    30,426
    Yeah, generally, not a great idea to add to the skimmer but, if you use some good sense, it can be done. Cal Hypo works well slowly into a skimmer....so does CYA assuming you know not to backwash for a few days.
    Baking soda does well for me in the skimmer, too.
    Jul 2011
    Monmouth County, New Jersey
    81
    That is good to hear that the CYA can go in the skimmer because that is how I added mine. It was granular and I put it slowly in the one nearest the filter. It went right through and I could see it go through the basket of the filter. We haven't had to backwash at all this summer. The pressure only moved one point. I think we are lucky with location. No trees, no dirt so not much gets in there and whatever does, I scoop out with the mesh bag.
    Hopefully I am done with CYA for the year.
    Built in October 2011, 16 x 26 x 20 L shaped vinyl IG steel wall pool, Hayward DE pro grid verticle filter 4800 pool, Hayward two speed superpump, 120,000 BTU Pentair Ultra Temp Heat Pump, Aqua Rite Salt system, 8' wide walk out steps, 2 skimmers, 4 returns, 2 main drains, 500 watt underwater light, intermatic mechanical timer
    Jun 2012
    Lafayette, Ca / USA
    260
    Follow-up : I usually pour my liquids (Chlorine, MA) in FRONT of the skimmer - in a long line in the direction the water is flowing .. I never pour directly into the skimmer ... Is that the proper method (in FRONT) ... or WHERE do you normally pour your liquids when adding?
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    38,397
    Slowly pour them in front of the return jet of water so they mix in the pool not in the plumbing and equipment.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jun 2012
    Lafayette, Ca / USA
    260
    Return Jet ? You mena where the water COMES BACK INTO THE POOL, right ??? Wow ... I've been pouring in front of the Skimmer intake because the pool serrvice did that when they turned it all over to me .. duly noted. Thanks
    30,426
    Yes.
