Results 1 to 8 of 8
Thread: Dunk Tank Water Safety
    Jul 2008
    Sinking Spring, PA
    58
    I was not sure which forum to post to.
    Ok, I have been asked to participate in a fundraiser at work. I will be in a Dunk Tank for 20 minutes. No problem there, except that I am the 15th person out of 16 to be in the tank. The temperature is forecasted to be 88 degrees tomorrow. The dunk tank will be in use form 10AM unitl 2PM when I get in. I am thinking this water will be very unsanitary. I think the tank holds 350 gallons. I am guessing no water treatment or filtration.
    I am planning to add some bleach before I get in. How much should I put in and how long should I wait?
    Any other suggestions?
    P.S. I am very particular about my water in my pool and hot tub. I test it a few times a week and keep it perfect. So you can imange I am a little freaked out about this dunk tank.
    Thanks!
    4th Year Pool owner in Sinking Spring PA
    46'x23' Free Form Concrete (34,000 gallons), Aqua Blue Pebble Sheen Finish, Pentair IntelliChlor SWG
    Pentair Intelliflo Variable Speed Pump, Pentair D.E. FNS Filter, Pentair MasterTemp heater.
    38,398
    Re: Dunk Tank Water Safety
    Ah the things we TFP members now worry about
    Since there is clearly not going to be any CYA in the water, you likely should not go over 10ppm on the FC. One cup (8 oz) of 6% bleach will raise the FC by 11ppm ... likely some of that will be consumed very quickly. This could actually result in more irritation and smell if the FC quickly consume and convert to CC. Not really sure what the "correct" solution is.
    Jul 2008
    Sinking Spring, PA
    58
    Thanks!
    Better safe than sorry.
    Jul 2008
    Sinking Spring, PA
    58
    Should I add 1/2 a cup wait a few minutes and add the other 1/2? Will that help?
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Toss part of a bag of Dichlor (before the event begins) in or ask them to setup a Trichlor floater in it (small spa sized would work). You get the CYA and chlorine in one shot.
    I wouldn't add more than 5 ppm of chlorine at one time. Levels higher than that, with no CYA, can damage clothing and cause skin irritation. 5 ppm of chlorine is well above shock level when CYA is really zero, and should take care of things. If you want to be really through, measure the FC level after 10 minutes and repeat the chlorine dose if FC has fallen to zero.
    The main issue is mixing the chlorine into the water. I'm not sure how you would do that other than getting into the water.
    38,398
    I kind of like the idea of dichlor, but wonder if it will affect too much and just might be overkill. The added CYA would at least make the FC less harsh. You might get less looks adding a spoon of powder than dumping chlorine in
    1 oz (1/16 of a bag) will raise FC by 12ppm, CYA by 11ppm, and lower the pH by 0.45
    Based on Jason's comment, might only want to start with half that though.
    1 oz of dichlor is appropriate. Dichlor includes CYA, and with almost any CYA in the water much higher FC levels are just fine.
