Thread: Multi-Port Valve Model
    crusemm's Avatar
    Sep 2011
    North Texas
    31
    Trying to find an operating manual with parts list for my multi-port valve. Unfortunately, all the labels are faded out to the point of being illegible. all i know is that it is a Purex-Triton. The reason I need it is to figure out what part to order to replace a leaking O-ring on a drain plug. Any help would be greatly appreciated, thanks.
    21,000 gal In Ground Plaster pool; Nautilus FNS 60 DE filter; WhisperFlo WFE-6 pump; Polaris booster pump and pool cleaner;Rainbow Lifegard HiFlow Chlorine Feeder (not in use); Purex Triton pool light;Hatteras spa light; Intermatic model PF122T Freeze Sentry pump controller; Sta-Rite U-3 Skimmer.
    22,551
    Re: Multi-Port Valve Model
    If you can post a picture of it someone will probably know what model it is. Or at least be able to match it to one.
    crusemm's Avatar
    Sep 2011
    North Texas
    31
    No longer an issue. I found a small crack in the valve body next to the plug port and had to replace the valve.
