Thread: CYA Testing Question
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    I have consistently tested 30 - 35 all season.
    When i went to test today i filled to the bottom of the label per the instructions ..... then used the last of my reagent and got 80% or so of the way to the top of the label.
    My reading was 50 or so the way it was mixed.
    So my question is does that make sense that with too little reagent i would get a higher CYA reading?
    Also ... approximately how many tests should i be able to do with the reagent supplied in the tf 100 xl test kit (i believe the xl is irrelevant and only give extra material for CL test)? ...... my kit came with a big huge bottle of CYA reagent but it was only 20% full.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: CYA Testing Question
    Quote Originally Posted by ship of fools
    No clue. Logic says if you had too much water and only a little reagent then it would be less cloudy - but with less total solution - I guess it could be cloudier than normal but I have no idea.
    That's weird. You should contact the company - my bottle of CYA reagent was totally full. This is the TF100 right?
    30,431
    Well, 20% full is not right, for sure. PM me your name and we'll get you fixed up.
    Also you dont really need to test CYA frequently. Unless you get a lot of splashout or overflow, your CYA wont really change.
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by march2012
    I don't .... maybe once a month or so
    AND ..... Dave was kind enough to ship me some additional reagent free of charge
    THANKS!
    Haywood Sand Filter
    Vinyl Liner
