Results 1 to 18 of 18
Thread: How to connect a SandPro 50 filter/pump to my pool
    U.S.A. - California
    32
    Hello! My name is Denis and I just installed my first pool ever.
    I got tired of the cleaning the filters and having to buy new ones every 2 weeks, So I got a SandPro 50 from GAME-GROUP (http://www.game-group.com/products/sandpro-50/)
    THIS IS MY PROBLEM!
    My pool has a totally different design from the one in the instructions
    [attachment=2:j9qy8vuj]productpools22.jpeg[/attachment:j9qy8vuj]
    My pool does not have holes like this one.
    [attachment=1:j9qy8vuj]4510-pool-scene-lr-300x192.jpeg[/attachment:j9qy8vuj]
    SO can someone please tell me how do I connect the SANDPRO 50??
    I tried by buying a long hose for the INTAKE of water BUT! since the INTAKE IS TOO HIGH the pump can't suck the water in:
    [attachment=0:j9qy8vuj]Screen shot 2012-08-20 at 8.16.33 PM.png[/attachment:j9qy8vuj]
    Am I suppose to make a hole on the pool??
    Please help me thanks.
    Pool: 5725 gallons
    Filter: SandPro 50 half horse power
    Type Pool: Above Ground Summer Scape
    Made out off: I dont know what type of material is made out off.
    Size pump and flow rate: Half horse power / I dont know the flow rate
    Date of pool intall: June 20th, 2012
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: How to connect a SandPro 50 filter/pump to my pool
    You can reverse your hoses...long hose to filter and short hose from fitting to pump, as long as that fitting is below your water level. But I wonder how the previous pump was hooked up
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Ahh...just noticed your skimmer. You can still try what I suggested as a temp solution. Long term you will want to replace the skimmer or modify it so it will accept suction plumbing to the pump.
    Funny that i'm not the only one with one n in my name
    Welcome to TFP
    U.S.A. - California
    32
    Quote Originally Posted by dmanb2b
    Welcome to TFP
    Well, If I reverse the hoses it wont work because the level of the water is a little below the hole.
    I was thinking about just using the skimmer and use the whole at the bottom of the skimmer with some sort of adapters but all the stores are closed right now and they don't know jack about Above ground pools.
    What about making a hole below the RETURN HOSE? is that possible do they sell some sort of kit?
    Pool: 5725 gallons
    U.S.A. - California
    32
    I found the answer to my problem:
    an adapter: http://www.game-group.com/products/skim ... p-adapter/
    Since I want the water to be suck IN from the bottom through the SandPro 50 and then to the top of the pool. All I have to do is hook the hose to the skimmer and tie something heavy to the hose so it sinks. I will post pictures later.
    Pool: 5725 gallons
    I am having the exact same problem right now. Trying to figure out how to get the sandpro 50 to work in my summer scape 12 foot metal frame pool that has a skimmer. Could you please tell me exactly what you had to purchase and how you put it together. And i guess more importantly if it is working better and worth the extra money to upgrade pumps. Thanks a million!
    Phoenix, AZ (East Valley)
    28
    You can use this adaptor from Game that "converts" the pump to a plain nozzle so you can connect a 1.5" or 1.25" hose to the bottom of the Intex wall skimmer
    http://www.amazon.com/GAME-4552-Skim-Fi ... ex+adaptor
    -S
    Phoenix, AZ east valley area
    • Intex 16' x 48" Frame AGP (5000 gal)
    • Intex 2650 GPH Sand Filter
    • Floaty Type Chlorinator
    • Intex frame-mount skimmer
    • Hayward Wanda the Whale Cleaner
    • EcoSaver Solar Pool Heater
    I see that you have the intex sand filter instead of the sand pro- i know that one is cheaper, does it do a good job? If i can get away spending less money that would be nice.
    Aug 2007
    near the swamp
    806
    the adapter and sandpro50 is a good seller of mine, customers are very pleased with it's operation and ease of use
    U.S.A. - California
    32
    Quote Originally Posted by ChristaW
    HI sorry for taking long to answer I did a better thing! it will safe you money give me a second so I can tell you what to buy..
    Pool: 5725 gallons
    U.S.A. - California
    32
    Quote Originally Posted by Shibiwan
    -S
    Yes the same one I post before
    Pool: 5725 gallons
    U.S.A. - California
    32
    Ok here it is instead of spending $20 on the adapter I went to Home Depot and found this:
    http://www.homedepot.com/webapp/wcs/sto ... =100346686
    It works GREAT! I do get a few drops but it works! take a loo at the pictures:
    [attachment=2:20basbvh]photo 1-2.jpeg[/attachment:20basbvh]
    [attachment=1:20basbvh]photo 3.jpeg[/attachment:20basbvh]
    [attachment=0:20basbvh]photo 4.jpeg[/attachment:20basbvh]
    Pool: 5725 gallons
    U.S.A. - California
    32
    IT works GREAT! Let me tell you how good it is. One day my pool was GREEN! and the next day the Green stuff (algae) WAS GONE!
    Take a look at how green it was and how it looks now.
    I opened this thread with pictures of before and after:
    is-borax-the-same-as-pool-conditioner-t52424.html
    You can get the pump for about $200 at the store and about $180 on line (not worth the wait, support small businesses)
    Pool: 5725 gallons
    28
    Quote Originally Posted by denisrenepl
    Nice - that's another part I should look into when modding my pool.
    -S
    U.S.A. - California
    32
    Glad to be of help!
    I think is on aisle 30 on Home Depot.
    I suggest you ger a LONG hose and hang something heavy to it so it sinks and you filter will be taking water from the BOTTOM of the pool, and then return it CLEAN on the top.
    Give the SandPRo 50 a couple of hours to ACTUALLY start cleaning the water. Sand Filters are slow. DO read the instructions and DO NOT backwash too often. The Sand filters NEEDS! some debris to clean better.
    Watch this video and the second part of it to learn about your filter.
    http://www.youtube.com/watch?v=w_J5KgIq ... plpp_video
    Pool: 5725 gallons
    28
    I love it. It has been working great, compared to the crappy 1000gph A-size cartridge filter that came with the pool. I was cleaning/changing the filters every 2-3 days and that got old quickly. When the filters got clogged the automatic pool cleaner (Wanda) didn't want to work properly.
    Found the 2650 gph filter on Amazon ($195 - free 2-day Prime shipping), did the surgery to cut out the two black outlet/return rubber fittings on the pool wall and replaced it with the larger fittings that came with the filter (the filter came with adaptors, hoses, fittings and even an eyeball return). Filled it with 100 lbs of filter sand and that's it. I've not had to mess around with the stupid filters any more, Wanda is happily cleaning without complaining and the pool water has been crystal clear. I'm really happy at how the filter has worked out.
    BTW, the same filter went on sale at WalMart for $30 less than what I paid for it on Amazon, so check there first if you're looking to get one.
    Cut out the black rubber wall fittings.....
    Crystal clear!! Thanks to TFP.
    U.S.A. - California
    32
    I see that you have a "duck" floating chlorinator. what do you put in there? tablets?
    and how do you keep the water so crystal clear... my is always cloudily no matter what...
    Pool: 5725 gallons
    28
    Regular 3" tabs (don't put more than 2 in there). I turned it down to the lowest setting (2 holes) and turned it down a little more so the two holes are half open.
    The floating turtle chlorinator is there to maintain the chlorine level constant. I adjust the chlorine levels with liquid chlorine or bleach....muriatic acid to balance the pH.... baking soda for stabilizer (about 3 lbs for my 5000 gal pool) and cyanuric acid granules to stablilize the chlorine. If the chlorine levels gets too high, I pull the floater out and leave it to hang on the outside wall of the pool (if you look closely you can see a rope around the turtle's neck).
    Chemical levels:
    FC - 4-7ppm
    TC - 4-7ppm
    CC - 0 ppm
    pH - 7.2-7.6
    TA - 70-80 mg/L
    CYA - 45-50 mg/L
    Our pool is totally under our large back patio so it's totally covered so I don't lose much chlorine to the sun, but we get a ton of dust storms out here, so dust gets blown in all the time. One storm will typically cover the floor of the pool with a thin brown layer of dirt. Wanda the Whale vacuums all that stuff out in about 2 hours.
