Results 1 to 9 of 9
Thread: Concrete sealer in pool
    acadianarose's Avatar
    Lafayette, Louisiana
    28
    Hopefully someone can help. My husband was sealing our concrete deck around the pool when before he knew it, the sealer got into the pool water. It didn't mix with the water. It left a film on top. I was able to skim a lot of it out with the net and what was left was little chunks almost like little bits of chewing gum. I put a pair of pantyhose over the skimmer basket to try to keep it from going in the lines and into the pump.
    What else should I do? I am kind of panicking here. Will it contaminate the pool water?
    Thanks for your help.
    Linda
    12 x 23 Fiberglass IGP Built 2012
    24 inch rainfall
    2 HP Superflo pump
    Intellichor SWG
    Pentair Clean & Clear Cartridge Filter
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Re: Concrete sealer in pool
    That happened to me last year. I skimmed out as much as I could.
    It didnt seem to effect anything else
    14500k inground, vinyl, built in 2007
    Hayward Sand Filter, 1hp Hayward pump, AquaCal electric heat pump
    Taylor K 2006
    22,553
    Skimming as much as you could and the pantyhose over the skimmer basket is probably all you need to do. It'll filter it's way out before long and be fine. The chlorine will oxidize what's left if anything.
    Aug 2007
    near the swamp
    806
    enzymes can help
    28
    Thanks everyone. The water looked pretty good this morning. Quite a bit of the remaining sealer was in the skimmer basket. It kind of looks like wax now. I think that the rest fell to the bottom. I will leave the hose on the skimmer basket for a couple of days just to make sure we have it all out.
    Linda
    BTW- What are enzymes?
    24 inch rainfall
    2 HP Superflo pump
    Intellichor SWG
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Quote Originally Posted by acadianarose
    Linda
    Hi, I am just curious.. How did he put the sealer on? spray, roll, brush.
    We always brush on starting at the back of the pool and working our way around. We brush because of the stamped concrete and want to get it in the grooves . It takes about 7 hours so I really would like to find a better way. Even with brushing my husband always drips some in the pool around the coping.
    Taylor K 2006
    28
    Our contractor told us to roll it on so that is what we did. We have stamped concrete also and rolling got it in the grooves really well. The problem was the sealant pooled in the lines cut over the expansion joints and dripped into the pool. We will brush that area next time. Lesson learned.
    24 inch rainfall
    2 HP Superflo pump
    Intellichor SWG
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Great. thanks.. I think next year I am going to buy rollers and just brush around the pool... Much better idea..
    Taylor K 2006
    28
    Quote Originally Posted by ajackson
    It worked well (except, of course, around the pool) and we were finished in no time.
    24 inch rainfall
    2 HP Superflo pump
    Intellichor SWG
