Thread: first tim eswimmers..are numbers okay???
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    My nieces and nephew will be the first swimmers in my new pool tomorrow and I want to make sure everything looks good enough for that. Here are the numbers this morning -
    FC 18
    CC 0
    TC 18
    pH 7.2
    TA 70
    CYA 90
    A couple of weeks ago I added a couple of pounds of borax to raise the pH to 7.6. Should I do that again?? Since this will be the first time I have swimmers in my pool is there anything special I need to do???
    Thanks for all your help!
    Karen
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    30,395
    Leave your pH alone. The SWG will tend to make it rise anyway.
    If you've been chlorinating solely with the SWG, turn it down a notch. 8-10ppm of FC is enough.
    Happy swimming!!
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Thanks Dave! Yes, I am chlorinating with the SWG but have had in low since the beginning. The CL is finally starting to come down from a high of 29 from the PB's original brilliant application of chemicals!
    I may just have to get in today first!
    10,700 gal IG vinyl
    2 skimmers
    Guest
    You want to maintain a 3-5 ppm FC level with the SWG
