Results 1 to 15 of 15
Thread: Has anyone filled up there pool with well
    May 2012
    Oconee, Georgia
    82
    With well water? How blog does it take going to build an 18x36 vinyl liner pool. Considering trucking water in. Not sure how tuff it will be on my well to fill it up.
    18'x36' inground vinyl liner.Pentair Sand Filter SD-60, Pentair EastTouch IC40 Salt Gen.
    Pentair Legend Cleaner. Pentair SuperFlo 1 hp pump. Color LED pool light.
    Taylor K-2006 (FAS-DPD) w/ SpeedStir. Pool Built October 2013.
    Jan 2010
    Randleman,NC
    620
    Re: Has anyone filled up there pool with well
    I top of mine&fill a little..But, alway's have atleast one load del. to house..All depend's on how you feel about your well&pump...Truck load of water has got so high..Use to be able to get 2 load's for what you pay for one..The top reason I would rather use truck'd in water is because it come's from a city source.So, then your water balance is usually perfect..Just start adding clorine&that's it..
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    30,401
    The most common source for iron in pools is when you fill with well water. If you have a pool with too much iron content, you will forever regret putting in that water and any initial savings you might see.
    Have your well water tested for iron and if it's below .3ppm, you are good to go. If it's higher, I would not use it.
    I used well water. At 300gpm it was hard to say no.
    Im sure my iron content is high. When i filled it i didnt clean the pipe long enough and got rust in the pool. Once it filtered out it was fine. Now my pool is clean, warm, and refreshing. YMMV.
    50,000 Vinyl IG Pool
    Pentair Challenger 1.5HP pump - 1.1SF
    2 Tagelus 50GPM filters
    SWG, Solar
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by Mmonaco
    It really all depends on the iron level. Sometimes, you can get by with adding a sequestrant. You have to know the value of the iron content first off though.
    May 2012
    Oconee, Georgia
    82
    I will take a sample of my water and have it checked. I will still have to use my well to add water to it and I would think over time it would all be well water anyway.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,763
    I am on a well that after softening has .5 ppm iron. I would truck in the water.
    There are a ton of things you can do to mitigate iron/staining. They're all quite expensive over time, and stains will come back every time the sequestrate exhausts itself, or the ph rises a little too fast, or the owner forecloses and innocent lil ole me buys the house
    If you truck in that first load of water, then you won't be as snookered if you forget once to pre-filter the water, for example, because the amount going in the pool will be diluted.
    I would hazard a guess that a season of jack's magic pink stuff, ascorbic acid stain treatment, and hose pre-filters would cost more than the truck full of water, although I know it's not cheap. Also, at some point, historic staining just doesn't completely go away, which for some people, might prompt the desire for a new liner a few years before it's otherwise necessary. The nanosecond I replace my liner I am trucking in water
    So that's my vote.
    But see what your reads are. Do you have a water softener for your house? Do you get any staining whatsoever in your dishwasher, toilet, etc? If you do, truck the water
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    BobinBaltimore's Avatar
    Dec 2009
    Northeast of Baltimore, MD
    116
    For an initial fill, I would definitely have it trucked in, which is exactly what we did. Not only because it will likely make for a faster fill, but also so you don't tax your well pump with running for hours on end. At our flow rate of 5gpm, it would have taken 3.5 days of continuous running to fill ours from the well. Some of your neighbors may also appreciate that you're not tapping the aquifer for tens of thousands of gallons (even though it may be the same aquifer where the truck gets its water!).
    We do top ours off using softened well water and all works just fine. Since our water does have a bit of iron and is slightly hard, using softened water makes sense. I'd note that we soften our water with potassium salt, and it has presented no issues with our NaCl-based salt water pool. Just keep an eye on the chemistry. Not a bad idea to have your well water professionally tested before hand so you know what's going in.
    25' x 37' freeform, 22,000 gallon saltwater, 3'6" to 6'6" deep, including baja shelf and benches, 120 ft EP Henry retaining wall
    Pentair equipment (CC420 cartridge filter, VS-3050 variable speed pump, IC 60 salt cell, EasyTouch), 200 sq ft pool house
    View our Pool Build - View our Pool House Build
    We did our 20k gunnite pool and have regretted it because of the staining...which I cannot get rid of. It is not due to iron but rather manganese in the well water. (We have had our well water tested twice...iron very low; manganese very high.) No one advised us to treat for stains until too late. I have tried Purple Stuff and other off-the-shelf stain inhibitors, but nothing has removed it.
    Does anyone have any ideas other then emptying the entire pool and hand scrubbing with something?
    May 2012
    Oconee, Georgia
    82
    Haven't had a sample checked yet but I did fill up a jar with water and let it sit put a table spoon of bleach and it didn't settle and the water is still clear.
    Sep 2009
    Greentown, IN
    914
    We top ours off with softened well water... had a leak this year so our pump got a workout.
    Our neighbor is on city water and we ran a hose from his outdoor spigot to our pool for the initial fill and paid what the difference was from his normal bill and the bill used to fill our pool. It was more expensive than we hoped, but saved from running the softener and well pump so much... plus no worry about the iron content in our city water (not the same everywhere)
    Whatever you decide to use it might be wise to get a sample of the water so you have a good idea what it will take to get it balanced when you start out.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Isaac-1's Avatar
    SW Louisiana
    6,711
    My pool has been filled from a well a number of times over the last 3 decades, never had a problem with with iron related to the fill water.
    Ike
    Jun 2007
    New Jersey
    653
    There are all different kinds of wells. In New Jersey's Watchung Range, we have been using well water exclusively since about 1950. There is zero iron (Officially: "Trace") and TA is about 50. Ours is too 'soft' for drinking supposedly, according to the lab tests, but three generations have done just fine doing so. We could fill my old 40k pool in 18 hours, but that well was just for the pool. We wintered empty so we did it every Spring. That well sat on top of an underground source that fed year-round springs as close as 30 feet from the pool, and could run irrigation 24/7 through severe droughts.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    30,401
    Anecdotal evidence of good wells only makes the rest of us jealous. I hope those anecdotes aren't taken as encouragement to fill a pool with well water without testing.
    Perhaps the most difficult pool problem here on the forum is metal staining......like the energizer bunny, it lasts and lasts and lasts.
    Test your water before filling from a well. 10 years later you'll be glad you did.
    May 2012
    Oconee, Georgia
    82
    K people had iron level tested she said it showed as 0. Did have some calcium it was an 8 in the hardness
