Thread: What is the difference between a 7-blade and a 14 blade cell
    My Polaris Auto Clear Plus SWG has died and I am researching a replacement. Many of the brands offer a 7 or 14 blade cell, but I can't seem to find any information describing what the difference is between them?
    Can someone provide some more details?
    Thanks
    ~40k gallon IG vinyl pool, Pentair 3HP <Not sure specific model>, Hayward Micro Clear DE4800, Polaris 380 Cleaner, Polaris Halcyon Booster Pump, Polaris Auto Clear Plus 1700 SWG.
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: What is the difference between a 7-blade and a 14 blade
    The more blades the more chlorine is produced as the salt passes through the cell. 7 blade systems are generally good up to about 20k gallons and 14 blade systems to 40k gallons. Do you have the part number off your current cell? Are you looking to replace the cell or the whole system?
    I am looking to replace the whole system as I have never had good results with the Autoclear and its around 3.5 years old. From what I understand it was discontinued, or shortly became so, after I purchased it.
    More information here about what I am trying to figure out can be found at this topic:
    post430342.html
    Thanks!
    Autocoear plus is only one size 40k gallons. System works well ppl just never understand it really. Like previous post said 7 blade smaller cell 14 larger. Always go with larger so then system can be on less 50percent for ex for 8 hrs instead of 100percent for 8 hrs with smaller cell. Makes cell last longer
