Results 1 to 8 of 8
Thread: Solar Fish
    May 2008
    rock springs, wi
    45
    Solar Fish
    Does anyone have any experience with the Solar Fish? A local pool store is recommending these over a solar blanket, stating that they are just as effective at trapping heat, and easier to use. What are your thoughts?
    27' AGP with 6' deep end (AquaLeader); 3/4 hp, 2 speed pump (Pentair); 22" sand filter (Pentair Sand Dollar); 2 4x20 Solar Bear panels with Goldline control valve
    They tend not to work very well unless the water is completely calm. A little breeze will disrupt the protective layer.
    i use them all summer but on cold nights i will take out my blanket and use that to keep the heat in
    JoshU's Avatar
    New Orleans, LA
    543
    Re: Solar Fish
    Quote Originally Posted by bobnamy
    They are not as effective as a traditional solar blanket but they generally do work well. As mentioned above it is much easier than a true blanket.
    - Josh
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Oct 2007
    Cedar Hill, TN
    251
    How do they work?
    Would it not get filterd out of the water, if it is just a layer on top?
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Butterfly's Avatar
    South Carolina
    10,045
    Hey, I had the same question last year. This thread may be helpful
    http://www.troublefreepool.com/viewtopi ... light=fish
    You're done SLAMing when:
    Oct 2007
    Valrico, FL
    542
    In general the liquid solar blankets do help. However the solar fish does have one thing you need to keep in mind. They are battery powered devices which you can not replace the batteries! So if the batteries die before all of the liquid is pumped out, you have to cut open the fish and dispense it that way. There are other similar products available which are cheaper and as good.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Guest
    The Heatsavr liquid (the stuff inside) does work to maintain some heat and prevent evaporation but ONLY if the surface of the water is undisturbed so the pump needs to be off and no wind blowing to produce surface ripples. They are probably more effective on indoor pools and on commercial installatiions where the liquid is introduced with a peristaltic pump. In a best case scenerio they can hold about 6 degrees overnight (most blankets will hold about 10). Most users see only about a 2-3 degree heat saving, if any.
