Thread: Is One Light Enough?
    May 2008
    rock springs, wi
    Is one underwater light enough for an 18x33 AGP? Does any one use two lights? What types? Thanks
    27' AGP with 6' deep end (AquaLeader); 3/4 hp, 2 speed pump (Pentair); 22" sand filter (Pentair Sand Dollar); 2 4x20 Solar Bear panels with Goldline control valve
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    I had a similar sized IG pool growing up with a single light. Works just fine. There are areas that are lighter than others, but it's all a little light. Certainly enough. If you are looking for a pool that has a uniform brightness -- use more, but most people don't care that much.
    Ask yourself how often you'll use it after the 'cool I have a new pool and I can swing [EDIT: ahem ... "swim"] at night' feelings are gone... then decide if it's worth the extra $$
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    Jul 2007
    North of Dallas
    my pool is 22 x 48 and we have one... it s enough. if you click on my pics, you can see it lit up at night. one more would probably be alright but maybe almost too much.
    My Pool - 18x24 fully setup Cabana, 22x48 gunite/quartz plaster (3-5-3 depth) & 8' spa w/ spill and 5' natural rock waterfall; Hayward DE filter/pumps/heater; Hayward Pro Logic controller; Phantom cleaner. Finished 06/01/07.
