Thread: Pump very loud
    Nov 2010
    South Central Kentucky
    283
    Pump very loud
    Yesterday, my pump got very noisy. I'm not familiar with pumps and their workings but from what I've been reading, I suspect motor bearings. What all do I need to check to verify this? I'm a pretty handy DIY guy, just don't have much experience in the way of pumps such as this. If it is the bearings, or maybe something else, where would I go about getting replacement parts?
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    22,548
    Re: Pump very loud
    The easiest way to tell is to take the back cover off and turn the motor by hand, feeling for any dragging or roughness in the bearings. With the power off of course.
    If it is the bearings, the seal is most likely in need of replacement too. You can buy just seal and bearings and replace them yourself, or you can have a motor or pool shop repair it for you.
    Re: Pump very loud
    Before you take the pump apart, check to see that the drain plugs on the pump are tight, check the little o-ring on them first. Mine were loose at the start of the season and my pump made quite a racket. Just something easy to try first.
    Tom
    In gound vinyl L, ~41,000 gallons, Pentair Clean and Clear Plus 420 cartridge filtter, Pentair 2 speed WhisperFlo pump
