Thread: How to push a liner back in the track
    May 2012
    Allentown, PA
    219
    I have a vinyl liner pool and in a few spots the liner has come out of the track. I can't push it back in by hand. What tool can be used to not damage the liner and get it back in the track?
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Re: How to push a liner back in the track
    Can you get in the water and start a couple feet down pushing up toward where its come out and when you get to the top push it back in?
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Someone told me that some pool guys will pour hot water on the liner and stretch it in place. I think they said they drained it a foot or two first and really heated up the liner with hot water.
    Lowering the water level a few inches will help. A hair dryer works well to warm up the liner (Do not overheat!). You can usually pull the liner up and push it back in the track. A flat tool can be used to push the bead back into the track. Be careful not to puncture the liner.
    Caution: Overheating or overstretching the liner can cause the liner to be damaged.
    Liner-loc can be used to secure the liner in the track and prevent future reoccurrences of the liner coming out.
    Support the site
    Jun 2012
    Louisville, KY
    266
    Another tip that has worked well for me is waiting for the sun to get on that part/side of the liner. Once warmed, it's very pliable and can just use your fingers to pull up into lip and get it seated on bead. With the liner in the shade, even on a super hot day, it was very difficult. So really the key is to warm it up a bit so it's more pliable.
    I'm too paranoid to use any kind of tool.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    This is my first post on this forum. I'm a new pool owner. This thread caught my attention because I'm having the same problem with my liner. The liner will not budget at all. It's rock hard. I'm a little worried I might break the liner or something if I pull too hard or use tools. I'm thinking I might have to call a professional.
    40x18 - 40,000 gallon -vinyl liner - sand filter - not really sure what else to say! Too new...
