Results 1 to 10 of 10
Thread: How to disconnect booster pump?
    I have a Polaris PB4 booster pump that's not working. I am able to manually rotate the shaft and have replaced the capacitor, but it still only hums when I try to turn it on. I would like to bring it into the shop to get it checked out. Problem is, I'm not sure how to disconnect it. While my main pump is connected with compression fittings, the plumbing that connects to the booster pump is sealed with what I assume to be joint compound.
    I'd appreciate any suggestions on how to proceed.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: How to disconnect booster pump?
    Looks like you can leave the plumbing there. Unhook the wiring. Undo the 6 bolts on the impeller housing, pull the whole thing out and take that to the shop.
    @Richard320: Thanks for the suggestion. If I do that, will I need to replace the mechanical seal?
    Richard320's Avatar
    Jan 2010
    18,967
    They'll do it at the shop. They'll fight the impeller off, too, if it's frozen on the shaft.
    and yup, that's a reducer.
    Intex 16'x48" easy set, 5000 gal. (AGP) w/ thru wall skimmer
    Hayward Pro Series Top Mount Sand Filter S180T / Hayward Pro Series XL 1.5hp Pump
    TFTestKit-100 -- The Pool Calculator -- Pool School
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by Flawed
    And an idiotic installation
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Quote Originally Posted by Qwaxalot
    Yeah, I'm no math wizard, but I reckon going from 2" to a 1" is cutting that flow in half.
    From what I've read, GPM is where it's at. Keeping the flow going is best.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    These booster pumps are not like regular pumps. The are optimized for high pressure low flow vs. High flow low pressure. Typically they are hooked up with 1" hoses.
    Quote Originally Posted by UnderWaterVanya
    Did I mention I'm no pool/spa wizard either?? Learn something new every day! Thanks for the Info, Vanya!
    Jun 2012
    Mint Hill, NC
    2,589
    LOL my first pool is the one I am ttaking care of now. I just read a lot and I happen to have the same booster pump. Another thread gave me the education on flow vs pressure - happy to pass it along.
