Results 1 to 7 of 7
Thread: Help! Elevated Spa Draining Back Into Pool.Pics inside of eq
    Hi everyone. Came across this site last night, and found it to be very helpful.
    Anyhow, I recently purchased a home, and it appears to have a great pool system that checked out. Only issue is that the spa drains into the pool. It seems to be a return issue, as the pooland spa both have in ground drains. I have 2 Jandy valves that will rotate to the correct position when I turn the spa on, and afterwards, revert to the previous position, which is shown in these photos. If I turn the filter pump on, it merely stays in this position shown in the photos, and does no movement before or after.These photos were taken with the filter pump on.
    I tried removing the top last night on the return valve and seeing if there was perhaps a loose connection, and all seemed to check out. I'm thinking if there's a possibility to have a setting that cause the valve to revert to the pool (or spa?) return being closed when not on, that it will solve the issue, but am not sure if that work work, or even how to do it, which is why I am here. I'm capable of fixing, just need to be directed to the way to do so. Any help is greatly appreciated.
    Thanks!
    -David
    38,540
    Re: Help! Elevated Spa Draining Back Into Pool. Pics Inside
    Welcome to TFP!
    This is usually due to a failing check valve. Yours is in the 2 picture by the spa jets label. Called an Ortega valve. The end should unscrew and they are rebuildable.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Re: Help! Elevated Spa Draining Back Into Pool.Pics inside o
    Thank you for such a quick reply!
    So to be clear, the end cap looking piece is the check valve? When looking at the site, I noticed check valve being discussed, but assumed it would have more of a valve appearance.
    I assume I just merely need to unscrew and use new parts, correct?
    Edit: Something like this? http://www.amazon.com/Pentair-Ortega-Va ... 49-3017511
    38,540
    I have never worked on that type of check valve, so I am not sure how the rebuild is done.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Looks like the water will just drain from the spa returns through the jandy valve that's half -open and down to the pool.
    [attachment=0:3222xm84]drain.jpg[/attachment:3222xm84]
    Also, it looks like there is a smaller line to keep some flow going into the spa even if the main valve is closed off. If that line has no check valve nor gate valve, it could be your drain path.
    Qwaxalot's Avatar
    Jun 2012
    439
    I think it most likely that the check valve (the horizontal gizmo with the cap on the end by the spa jets label) needs to be cleaned or rebuilt.
    Unscrew the cap and check for debris caught in the valve. No debris? Check the spring, it may be bound or corroded. You can still get parts for them (it's an "Ortega" check valve).
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Thanks guys. It was the valve. Spring was completely corroded and flimsy, and seat inside was dirty, and mangled. New parts already on order.
    Much appreciated.
