Thread: Home from vacation results..?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    After getting home from vacation with SWG and pump on timer:
    FC: 14.5
    CC: 0
    pH: 7.8
    CYA: 60
    TA: 60
    Before we left:
    FC: 6
    pH: 7.4
    Should I bother adding acid or is the high pH a side effect of the higher chlorine? I'm assuming it's safe for the kids to swim since I'm below shock level.
    Looks like the kids won't need a bath tonight!
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Home from vacation results..?
    Don't adjust ph until you measure it when the FC is below 10 ppm, it is probably reading high right now.
    38,301
    Just dial the SWG back and check the pH when the FC gets below 10 ... enjoy!
    Posted from my Droid with Tapatalk ... sorry if my response is short
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Looking pretty good. I bet that water is clear. Reduce runtime or percentage on SWG. Sounds like it was set a little high before vacation. Wait to test pH after FC comes down.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
