Thread: new filter gauge installation help
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    487
    Pentair has sent me a new filter gauge to replace my new one that doesn't work. I want to make sure I don't muss up something here. Do I need to turn the pump off before I unscrew the old and replace it?? There is plumber's tape there now which makes me think that water will spew??
    Thanks bunches!
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Yes, water will come out if you remove the old one with the pump on. Shut it down, put a wrap of tape on the new one and swap them.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    487
    Okay.....will do! thanks John!
    10,700 gal IG vinyl
    2 skimmers
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    487
    Okay...well, I changed the filter and it's till reading "0". Is there something more to it than just screwing it in???
    10,700 gal IG vinyl
    2 skimmers
    Quote Originally Posted by midtngal
    There isn't anything to it other than screwing it in. Sometimes debris will plug up the opening. You can take apart the filter and see if the opening is clear. Or you can take off the gauge and see if you can clear the opening. Make sure the teflon tape you put on it isn't blocking the opening.
