Thread: Pool Motor Not turning!
    What would cause the pool pump motor to just make a wining sound, but nothing turns. I can turn everything with my hand but the motor is not turning anything.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pool Motor Not turning!
    Welcome to tfp, bdhughes
    If the shaft moves, then it is likely a start capacitor or a centrifugal switch.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Does the shaft not turn when the motor attempts to start? If not then listen to Linen's answer.
    If the shaft turns when you turn it on but "nothing" happens in the basket of the pump then It could be the impeller has broken free
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Linen, That sounds like the issue. Everything turns by hand freely but the motor just whines when plugged in. I am not a expert on motors are those 2 suggestions easily self repairable?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yes, if you are handy.
    If you have a multimeter here is how you can test the capacitor: http://www.stpats.com/ElectricMotorR...#testcapacitor
    This thread may help, it describes cleaning contacts for the centrifugal switch: http://www.troublefreepool.com/haywa...ng-t51940.html
