Thread: Closing my Pool with One Way Winter Pool Valves
    Central Connecticut
    159
    [attachment=0:3qysbkxu]one-way-winter-valve-w1115.jpeg[/attachment:3qysbkxu]
    I saw a product on the internet for closing your pool without draining the water below the returns. You just replace your eye balls with these one way valves, blow out the water, add pool antifreeze and your done with your return lines.
    My question is .. has anyone ever used these valves before?
    I saw it at this site.
    http://www.poolcenter.com/winter_pool_s ... sories.htm
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    Jul 2009
    Olney, MD
    218
    Re: Closing my Pool with One Way Winter Pool Valves
    Yup. Have used them for two years. They work just fine. Although I think next spring I am going to try to drain/vacuum the antifreeze out of the line instead of letting it just flow into the pool, I think it caused a lot of foaming. It comes with a handy tool to help get the fitting off in the spring (they get a little stubborn over the winter).
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Central Connecticut
    159
    Thanks J20832.
    Do you also cover the face of the skimmer ? ...... or just leave the water in there with a plastic winter skimmer guard/plug?
    I'm just a little nervous not draining the water below the returns and skimmer and blowing them out. But, it would be nice not to have to drain the water and use these valves .. if I can be confident they work.
    Also, approx. how much antifreeze are you using in each line?
    Rich
