Thread: Rake mesh
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Rake mesh
    Does anyone make a finer mesh leaf rake? I get a lot of floating fine "stuff" (probably pollen), that always ends up near one end (direction of wind, away from skimmer). Just falls through a normal scoop.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Re: Rake mesh
    I think I've read that some people have put a leg from pantyhose over their scoop... you might want to give that a try if you cannot find a tighter mesh.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,975
    Re: Rake mesh
    That's what a vacuum is for.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Re: Rake mesh
    My wife would kill me if I used her Hoover (or her panty hose)
    DIY chlorine feed
    BBB
