Results 1 to 9 of 9
Thread: How warm is too warm pool water???
    Aug 2007
    Austin, TX
    343
    Hit 90 degrees in the pool today for the first time with the aid of the solar system. I had the solar a bit high, so I bumped it down to 85 at 3pm today. Yesterday the pool was a cool 81. I decided 90 is just too warm.. I like 82-88 myself. Now 82 degree water seems almost too cold... Getting close to using the solar at night to cool down the pool....
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, 90 is too warm!
    86 ish is purrrrrfect!
    You're done SLAMing when:
    Feb 2008
    Miami, FL
    38
    For us - 84 feels cool, 85 is slightly warm and 86 is about the max.
    Miami, FL
    18,000 gallon 17 x 35 in-ground diamond brite, Fafco solar, SWG, Barracuda G3, well pump - Biscayne Aquifer CH=250
    Mar 2007
    San Rafael, CA USA
    12,082
    This is definitely a question of personal preference. I like 88F water as my ideal -- I can walk in the water without any shiver and stay in it as long as I like. Of course, it's not great if you do a reasonable amount of exercise (swimming or activity), but for lounging around or only a little swimming it's great for me. My wife also prefers around 87-88 as she does mostly therapy exercise and needs to be in the water for around 45-90 minutes. I agree that 90F starts to feel like a bath and too warm. I'm also pretty skinny and have been underweight all of my life.
    Richard
    Oct 2007
    Valrico, FL
    542
    I had my system set at 90 also. We liked the warmer water for swimming in the evenings. However with the warmer days, I have lower the temp to 86. I still have the"spa" (therapy jets) set to 100, so when I turn them on during the day, the solar heater comes on, and I have warm water jets!
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Guest
    78 is what my water is at now and its AWSOME. i wish it would stay thatway. its chilly to get in, but once your in, ITS PERFECT.
    in the summer my pool will get up wards of 90 and we have to stay out becuase thats too warm, thankfully the ocean stays at a nice 85.
    Guest
    I like mine around 86-88.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    82-88 is good, but it largely depends on the outside temperature. If it's cool outside, I like 88, but if it's very hot outside, cooler is better. It's been just over 90 here the past couple of days, but the water is still around 85 so it's very refreshing. Unfortunatley, it doesn't usually work that way.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
