Thread: Pool Pump is not drawing water from the pool
    I just replaced my old Hayward pool pump with the same 2 HP model. The problem is it is not drawing any water from the pool, even after I thoroughly primed the basket and intiake hose.
    What is the cause of this and how can I fix it?
    My name is Mike and I am brand new to this website.
    Please Help!
    Mike
    AGP 8600 Gal Intex Ultra Frame 18x52
    Hayward S180T Sand Filter
    Re: Pool Pump is not drawing water from the pool
    Is it possible there is an air leak somewhere, maybe a missing gasket on the skimmer basket or a loose union? Skimmer basket gasket got me once.
    Dan's Pool: 40K gal gunite pool - 50 by 18 and 8ft spa, 2 Aquarite 40K SWG, Aquamatic pool cover (rarely used), 60sq ft De filter (Jandy), Heat Pump and Gas heater (rarely used), O3 generator, just started borates
    22,553
    Welcome to TFP.
    If it won't prime there has to be an air leak on the suction side. Maybe a missing or deformed o-ring.
