Thread: SWG allow you to have a higher CYA with lower CL levels
    What about pumps or the liquidator that continually add FC just like the SWG? Can you use lower FC and higher CYA with pumps/liquidator?
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Oct 2010
    michigan
    284
    Re: SWG allow you to have a higher CYA with lower CL levels
    i believe its the salt that makes the difference
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I've never seen a definitive answer, but the consensus is that the high chlorine levels within the cell make up for the higher CYA level. It isn't the salt.
    Mar 2007
    San Rafael, CA USA
    12,082
    It's partly the more continuous dosing and partly the high chlorine level at low pH near the chlorine generation plate and maybe partly the higher salt level. All probably contribute, but we don't know by how much individually. My guess is that it's mostly the first two factors and the salt level is minor. Automated dosing is probably better than manual dosing but not as good as the saltwater chlorine generator in terms of the minimum FC/CYA ratio to prevent algae growth.
