Results 1 to 8 of 8
Thread: Am I dreaming!! Somebody pinch me!
    BBB Method...
    Can it be this easy!!?? My pool says so!!! We have been up and running since a bit before July.
    I have been following the BBB method since day one. Pool has always looked amazing! Thanks to trouble free pool and all the wonderful members here.
    I had to post this picture up because I added my borates 2 days ago and the pool looks amazing! Can you tell I'm excited!
    Well, I got the muriatic acid in, got the borates in via 3 1/2 boxes of borax. The calculator says 3.9 boxes and that is a bit closer to what I added but I did cut it shy because I only had enough money in my budget to get the one concentrated jug of acid. It may have been a little less than one gallon though, i think it said 98 oz of 31.45% so my plan was less borax, let everything settle down and then adjust accordingly. Well, the borate test strips managed to not get in the bag at checkout... at least I didnt pay for them either. So until I can make it back to the store I cant check the borates. I am not too concerned about that for right now since I followed what the calculator said.
    I assumed I was in the clear because of my test results, what do you all think? These are post borate addition results
    FC: 5+
    cc: 0
    TC: 5+
    PH: 7.8
    TA: 90+
    CH: 160
    CYA: 40
    Borates: ?? (but my water rocks!!!)
    I add about 1 cup or less of 10% bleach a day (in the evening) to maintain the 5+ FC. I have to admit that I have never done an over night loss test.
    Thanks again to eveyone!
    5K gal (16' round), vinyl UltraFrame AGP, stock cartridge intex filter/pump
    using(learning) TF-100 test kit with BBB method
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Am I dreaming!! Somebody pinch me!
    Looks good magtiki!
    May 2012
    Boyd, Texas
    93
    I feel the exact same way. I've always heard of people giving up on having a pool because it was SOOOO much work...truthfully kinda had me scared when I ordered my pool. Now two months into it i've never once had a problem, only add a little acid here and there, let the SWG maintain the chlorine. Just bought some borax to start the next step now that I have gotten my TA down to acceptable range.
    So as Magtiki said, thanks everyone!
    6500 gal, Intex 18'x48" above ground, 1hp Pro Sand Filter, TF100 Test Kit
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I wouldn't worry about testing for borate level. The strips aren't that accurate and anywhere between about 45 and 70 ppm will do just fine. I would just add borates based on the Pool Calculator, recommendations for 50ppm and call it a day.
    chiefwej
    Quote Originally Posted by chiefwej
    ........The strips aren't that accurate........... add borates based on the Pool Calculator...... and call it a day.
    what do you guys do say at the beginning of the next swimming season, thats when it is recommended to check and adjust? Are the strips accurate enough to use to calculate adjustments or is there another / better way to test borates?
    Feb 2008
    Denton, TX
    5,061
    Borates can be accurately tested with strips.
    is there one brand or type strip better than another???
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Most people have the best luck with Lamotte Borate (only) strips.
