Thread: Pool Houses!
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Pool Houses!
    Hey folks,
    Post up pictures of your pool houses, exterior and interior (if possible).
    Looking for ideas
    Thanks
    Alex
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: Pool Houses!
    My entire construction of my pool house is at http://www.golfmd.com/baurphotoalbum/poolconstruction
    I created mine by finding ideas by simply googling pool house. The story is in the website above. I just adjusted the design when I started building it. Took a while and it's still standing now. Off to finish the putting green and the driveway.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Re: Pool Houses!
    I'd like to see some too and hear about the building process and costs. We are hoping to build a detached garage that is essentially 1/2 garage and 1/2 kitchen, bathroom with a covered porch on the side the pool will go on. We will likely build the pool and the shell of garage together, then finish out the garage in stages as our finances allow.
