Thread: When to backwash DE when filtering a really dirty pool?
    Aug 2007
    Northeastern Ohio
    178
    While filling my pool for opening, my well pump started sucking up dirt overnight. Now my pool is a lovely shade of brown.
    I have my DE filter going, and we've been bumping about once an hour (the pressure rises 10psi in that time). My manual tells me I need to backwash "when the gauge pressure rises more than 10 psi (.70 Bar) in less than a 24 hour period". Obviously when filtering a really dirty pool, I would imagine this doesn't apply (otherwise I would've backwashed about 10 time now!)
    How do I know when I truly need to backwash this thing?
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar Panels...now if only there was some sun to shine on them!
    Apr 2008
    Central Texas
    326
    I backwash mine when the pressure is 8-10 PSI higher than when it was last backwashed. I've noticed that the flow rate drops considerably as the filter backpressure rises.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    You need to backwash when the pressure doesn't go down enough after bumping, say when you are getting less than 4 psi back after bumping. Typically that is much sooner than 10 bumps.
    Jul 2007
    North of Dallas
    207
    If the pool is truly dirty, it's possible that you will need to backwash several times or more in a short period. If the pressure goes up 8 or 10 pounds, then it's telling you the filter is holding enough dirt to slow the flow and it's time to backwash. Some people, when first filtering a really nasty pool will have to backwash 2 or 3 times in 6 or 7 hours.... so read your gauge and watch the flow.
    My Pool - 18x24 fully setup Cabana, 22x48 gunite/quartz plaster (3-5-3 depth) & 8' spa w/ spill and 5' natural rock waterfall; Hayward DE filter/pumps/heater; Hayward Pro Logic controller; Phantom cleaner. Finished 06/01/07.
    RedishConstruction.com
    Aug 2007
    Northeastern Ohio
    178
    Thanks for the replies!
