Results 1 to 13 of 13
Thread: Which test kit?
    Mid Missouri
    227
    Which test kit?
    Hi,
    I jumped into pool ownership late in the season this year. We got an 18'x48" easy set, I figured it would be good for me to practice pool maintenance on; as well as give the kids a couple years to get taller before we switch to a deeper hard side pool.
    I've learned a lot here that is helping me plan to be ready for next year. Two things I know I need to do heading into next year are to upgrade to a sand filter and get a better test kit.
    So my question on the test kit is; TF-100 or K-2006? Our water supply has a very high TA (290 ish from the tap), so that is something I will definitely need to be able to monitor and adjust. Should I lean towards the K-2006 since it includes the acid demand test, or can I do what I need to with the TF-100? I'm leaning towards the TF-100 because of the association with the forum, but I've also seen people ask for acid demand results dealing with TA.
    Thanks, Josh
    18'X48" Intex Easy Set, 2650 GPH Intex sand filter, Intex SWCG, Intex deluxe skimmer
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Which test kit?
    There is really no need for acid demand when you have ph and TA results (and borate levels...if you are using borates). Basically, the acid demand is not as informative as knowing those other parameters...i.e. a poor substitute.
    I would vote (and have bought) for the TF-100, it really is the most bang for buck (most reagent volume) and Dave has fast shipping.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Which test kit?
    Oops, I forgot...Welcome to tfp, jcp
    Mid Missouri
    227
    Re: Which test kit?
    Linen,
    Thanks for the reply. I went back to the pool calculator and see that it is quite simple to figure out with the ph and TA entered in.
    Another question in regards to lowering TA. Is it ok to add the amount of acid required to lower the ph to 7.0; even if it exceeds the maximum amount per application recommended on the acid container?
    38,394
    Re: Which test kit?
    We recommend you lower the pH to between 7.0 and 7.2 while trying to lower the TA (I assume you have seen the article in pool school?).
    It is fine to add any amount you need by pouring slowing in front of a pool return. You may want to start out with a little less to make sure you do not lower the pH too much at first.
    Mid Missouri
    227
    Re: Which test kit?
    Yes, I got the 7.0 ph figure from Pool School.
    Mar 2011
    Grand Rapids, Michigan
    279
    Re: Which test kit?
    I have the TF100 and the Speedstir. The Speedstir makes testing alot easier and fun, too!
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Which test kit?
    You can do acid/base demand with TF-100 - you do need more reagents however:
    extended-test-kit-directions-t25081.html#p206394
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Re: Which test kit?
    I bought the K-2006 last week and wished I would have gotten the TF 100 I already had to order new reagents for FC and CYA (I was in the shocking process and alot of FC reagent)
    I did order them from the TFTest site. The shipping was super fast.
    14500k inground, vinyl, built in 2007
    Hayward Sand Filter, 1hp Hayward pump, AquaCal electric heat pump
    Taylor K 2006
    Mid Missouri
    227
    Re: Which test kit?
    Yep, I'm going with the TF-100 and the Speedstir.
    Re: Which test kit?
    Quote Originally Posted by jcp
    Hi,
    Thanks, Josh
    I have the K2006 and I really like the acid demand test. It is really helpful to know how many ounces of acid I need when the color is off the charts.
    For volumes I just buy the 2 ounce taylor replacements
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Which test kit?
    Quote Originally Posted by march2012
    Do you just refill the existing smaller bottles so you can store the kit the same way?
    Re: Which test kit?
    Quote Originally Posted by UnderWaterVanya
    Yeah, the tips just come off
