Thread: Close in stages?
    lee872's Avatar
    Central Massachusetts
    59
    Close in stages?
    I'm thinking about closing my pool in stages this year. Put on the mesh cover in early Sept, but leave all the plumbing in place. I'd run the pump for a few hours a day, fold back the cover to test and add bleach as needed. Then in mid to late Oct, fold back the cover to get at the returns and do the actual winter closing. Does anyone have experience with this? Or do you see a reason not to do it this way?
    What I hope to accomplish is a cleaner pool in the Spring, and a fall where I don't have leaves and pine needles in the pool.
    Thanks!
    35,000 gallons - inground vinyl liner -- sand filter - 1 HP, 50.76 GPM - Aqua Rite T-Cell 15 SWG - Dolphin Apollo Plus - TF-100
    Apr 2011
    Lynchburg VA
    393
    Re: Close in stages?
    I don't see any reason why it would not work. I have thought about it myself but I like the look of the opened pool and don't mind the upkeep during that time.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    lee872's Avatar
    59
    That was me in my previous house. In this house, my neighbor has pine trees along the boundary line, and that is a lot to keep up with. Droppings are already starting this year. In fact, once the pool is covered I'm going to have a tree service come out and give me the bad news on cost to trim the overhanging branches. The trees are 80 - 100 ft high as near as I can figure. I can't use that end of the patio because of sap, and sap droppings are almost reaching the pool this year. The former owners had the branches trimmed about 5 years ago, so I guess that's something I'll need to do also.
    Sep 2010
    Noblesville, IN
    104
    We have an automatic cover and that's basically what we do all the time. If we aren't swimming, it's covered. We do try to take it off at least every couple days to air it out so to speak.
    16 x 32 15300 gal. IG Vinyl Jandy pump, Jandy sand filter, Paramount circulation system, Automatic pool cover.
    lee872's Avatar
    59
    Thanks HoleInOne. I think I'll give that a try this year. Was your cover an original install with your pool, or did you add it later? I'm wondering if it's something I should investigate given my pine tree issue.
    Sep 2010
    Noblesville, IN
    104
    Yes ours was installed when we got the pool but I think you can add them after the fact. Mine is from here: http://www.automaticpoolcovers.net/
    Nice unit. i would recommend them.
