Thread: Bioguard MS-10 Power and generating lights comes on and off
    Hello - I just got back from vacations and found my pool all green with algae. I noticed that the control unit on my MS-10 by BioGuard (installed in 2004) shows power light and Generating sanitizer light coming on and then going off after few seconds. I also noticed that cell voltage displays voltage not as a constant number but as numbers going up from 3 to 17.9 and then down to 3 again. Amp are at zero - but it is possible that it is b/c the generating sanitizer light is off.
    Did anybody here run into the same problem? Is it cell of the unit itself that is causing the issue?
    Any help greatly appreciated.
    Re: Bioguard MS-10 Power and generating lights comes on and
    It looks like i may have a same problem as here: aquarite-not-generating-lights-not-on-t18264.html
    Anyone knows if the Aquarite unit they refer to is in anyway related to BioGuard MS-10? It would be nice to know before i break it apart and look for that current limiter.
    Thank You,
    Les
