Results 1 to 8 of 8
Thread: Very high chlorine with SWG
    Jun 2012
    Hudson Ohio
    47
    Chlorine has been climbing.Turned down the SWG to 1 hour per day.Have not been swimming for a week and a half due to colder nights and no heater. Is it safe to turn off the SWG?
    18 x 54 Sharkline Matrix pool. 7800 gallons.
    Pentair Optiflo 1 1/2 HP 2 speed pump
    Pentair Clean and Clear 150 Sq Ft cartridge filter
    Hayward H100ID Heater. Purchased all from Poolsupplyworld. TF-100 TEST KIT
    38,354
    Re: Very high chlorine with SWG
    Of course, we need a full set of test results to offer any informed advice. At a minimum CYA, FC and CC.
    We do not know if what you consider "very high" to be different than what we consider high ... very dependent on your CYA.
    Jun 2012
    Hudson Ohio
    47
    Sorry for the post with no test results.Just did the daily test..Will do a weekly test and post those results.
    Jun 2012
    Hudson Ohio
    47
    FC 11.5
    CC .5
    PH 7.6
    CYA 60
    TA 280
    Have never tested the salt level(we have been at 5ppm all summer with the chlorine levels).
    38,354
    What are you using to test the water?
    Jun 2012
    Hudson Ohio
    47
    TF-100 Kit Have been using this kit since the beginning of June. I do the daily test and the weekly test
    38,354
    So how long were you running the SWG before you turned it down to 1 hour? Have you had a cover on it?
    Kind of puzzles how it suddenly got high recently.
    BTW, as you likely know, the minimum FC for your CYA of 60ppm is 3ppm of FC. Also realize, you are safe to swim up to shock level FC. For your CYA, anything under a FC of 24ppm is not a problem.
    So if you can stand the weather and pool temp ...
    Jun 2012
    Hudson Ohio
    47
    Have been running the SWG at 2 hours for the last 2 1/2 months and just turned it down to 1 hour yesterday and solar cover is on all the time.. Need to buy a wet suit The pool temp is 74
