Thread: Filled pool but have question!
    Hello,
    My name is Michael and I just installed a Intex Ultra frame 18'x54" AGP. I used all your methods and it worked great. My problem was after the water was added and all was settled.
    Being that I used at least a 4" base of compacted sand in a 20' circle, I used small 6"x8" pieces of plywood under each of the 18 legs and kept it away from the liner as you suggested and then leveled each leg. Well after filling the pool, the legs seemed to out and the plywood moved in so now the plywood is under close to half way under the liner and I feel them when I put my feet on it, some are hard cut and seem to feel the points and edges, not real pointy. I did place the plywood under the tarp that came with pool. Should I jack up each leg as you have in your diagram and pull the pieces back away from liner now that the pool has settled, can I do that without draining all the water. Or do you think it will be ok without doing anything. I'm just afraid of after time the edges piercing the liner.
    the picture I added is how it looked before the leg slid out after filled and the plywood slid under the liner, also I didn't have the legs screwed to the plywood as this person did in the photo.
    Please advise if you can,
    Michael in San Antonio
    22,550
    Re: Filled pool but have question!
    I would jack it up one at a time and slide the boards back.
    Thanks Bud,
    This is how another person did it, it looks safe.
    Apr 2012
    SW Ohio
    456
    I personally would move them you don't want it rubbing a hole in the liner......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    30,421
    Please post only once. Michael, I deleted your duplicate
    Sorry about the duplicate post , and thanks all for the help.
    Michael
