Results 1 to 15 of 15
Thread: Diagnosing Pool Plaster Problems
    Jul 2011
    Arizona & California
    799
    Plaster Discolorations – New white pool plaster can discolor (darken or turn gray) from adding excessive calcium chloride set accelerator, from late hard troweling, from thin and thick areas due to an uneven shell, etc. Gray (or grey) mottled discoloration (also known as “water entrapment” or “hydration”) is smooth to the touch and difficult to lighten, may be remedied by acid washing, sanding, or torching the surface, but these processes are generally detrimental to a plaster finish and the discoloration often returns later. Late hard troweling can cause “trowel burn” which darkens the plaster color in localized areas. Severe mottled color variation from calcium chloride or finishing issues may occur quickly once filled with water, or take several months to become visible.
    See these threads: How White Pool Plaster Can Turn Gray
    How White Pool Plaster Turns Blotchy
    Gray Mottling Plaster Discoloration
    White Spotting and Streaking – New Plaster (white or dark colored) may develop smooth white (lighter color) porous (soft) spots and streaks (sometimes incorrectly termed as “spot etching”) resulting from the addition of water to the hardened surface during late hard troweling in plaster containing excessive calcium chloride. This late hard troweling disturbs surface aggregate, and added water penetrates around that aggregate and spreads laterally through the porous paste caused by accelerated shrinkage. Beginning as excess porosity around the disturbed aggregate, soft spots expand and sometimes coalesce into larger affected areas as cement components are dissolved away over time. Disturbed zones along accent or surface tile, around fittings, etc. may also display this non-removable deterioration. This type of problem usually takes several months to show up.
    See this thread: White Spotting of New Plaster Pools
    Whitened Discoloration of Colored Plaster – In time, integrally dark colored pool plaster may begin to show whitening (lighter color) either uniformly or in patterns. Uniform discoloration may be caused by using incompatible admixtures: specifically color pigments and calcium chloride. "Organic" and "Blue" pigments are prone to become bleached out by chlorine, and should not be used in pool plaster applications. These colored plasters may also be discolored (white streaking or spotting) from the addition of water to the surface or to trowels applied to the surface during finishing. These discolorations are permanent, unless major sanding is performed. White discoloration may be calcium scale developing due to imbalanced water, such as high CH, high TA, and overly high pH. Fortunately, the white scale can be removed by either sanding or an acid treatment.
    Spalling – Spalling is the flaking or peeling of a thin layer (1/8 inch or less) of plaster, usually in small areas on steps and shallow end floors. It is caused by the over-troweling of the surface when the underlying paste is wet but the surface cement laitance is dry. It can also be caused by adding too much water while troweling. This usually results from improperly timed troweling, or from hot, windy or dry days. When water evaporates from the surface faster than mix water bleeding up can replace it, and then when that surface dry crust is troweled, a weakened subsurface zone is created that will be prone to spall. Spalling may occur immediately, or years later when the pool is drained, etc. Spalls may be sanded, although the pool may need to be replastered if large areas have spalled.
    Delaminations – This is the separation of an entire new layer of plaster from its underlying substrate, whether that is old plaster, gunite or shotcrete, etc. Delaminations are usually first seen as a round surface area that has raised or pulled away from the wall, often with small cracks and nodules forming. This defect is usually caused by improper surface preparation to create a good bond during a replaster. It may manifest itself within a month or two or several years later when the pool is drained and the plaster dries out. Ground movement such as during earthquakes, can also initiate bond failure. Occasionally, some plaster areas completely pop off, exposing the underlying surface. Delaminated areas may be patched if small, but larger delaminations require replastering.
    See this thread: Calcium Nodules in pools
    Calcium Nodules – Nodule spots are a raised and rough form of calcium efflorescence that sporadically forms on a plaster surface. Nodules may be circular volcano-type formations or stalactite-like drips down the plaster wall. They are most often associated with plaster delaminations (as mentioned above), or with severe craze cracks, either of which allow balanced water to penetrate the surface and dissolve and bring calcium from the interior to the exterior of the pool plaster layer. Nodules may be removed by sanding or scraping, but generally continue to form again and again. See this thread: Calcium Nodules in pools
    Craze Cracks – Crazing is an excessive amount of surface shrinkage cracking which can result from an overly-wet plaster mix, from excessive calcium chloride set accelerator added to the mix, from the adding of excessive water while troweling, or from excessive drying of the plaster before the pool is filled. Crazing often leads to other problems including calcium nodules, staining, and provide a home to black algae. Excessive crazing may require replastering.
    Identifying Curing Effects on New Pool Plaster - Newly plastered pools must be filled at the right time, and any water exposure must be even and uniform. Filling a pool too early can result in a weakened and deteriorated paste surface, especially in the bowl of the pool where the effect is worse because it may be exposed to fill water mere minutes after final troweling. The optimum fill delay (time between final troweling and filling the pool) is at least six or more hours. (Moderate temperatures and sufficient humidity is also necessary for proper hardening and curing of plaster). This fill delay is often realized for the upper half of the pool, which may not be submerged for a day or longer depending on water pressure, while some plastering crews start the fill before they leave and thus compromise the lower areas of the pool.
    Wetting of parts of the surface by rinsing down the deck, rinsing off pool steps or areas where debris falls, etc. must also be avoided, since the uneven exposure of fresh plaster to water makes permanent discoloration. The fill must also be continual – pauses in the fill may result in “bathtub ring” permanent discoloration.
    Staining – Fill water containing excessive levels of iron, copper, or other metals can cause various colors of staining and should be filtered and removed, or at least treated before the pool is filled, or, if that is not possible, immediately upon filling the pool to the surface tile level. This kind of staining can usually be removed by acid washing, sanding or chelation. Some of these techniques are invasive to the surface, and avoiding staining is better than removing it later.
    Scale or Etching from Improper Chemical Addition – Pool chemicals need to be added to the water in a manner that prevents aggressive/scaling amounts of chemical or imbalanced water from affecting the new plaster surface. Acid should always be pre-diluted before adding, salt should only be added after 30 days of plastering, and should not be allowed to sit as a solid on fresh plaster. Cyanuric acid and soda ash must also not sit as a solid on new plaster.
    Water Balance, Scaling and Etching - Before filling a new plaster pool, the chemistry of the fill water should be determined. Tap water that is too soft (aggressive) can create plaster dust, and etch or weaken the new plaster surface, and should be balanced before filling. Of course, once the pool is filled, the Saturation Index (or CSI) provides an excellent guide for maintaining pool water in a manner which will minimize detrimental effects to the new plaster surface. Scaling is caused by overly scale forming (high positive CSI) water. Sanding or an acid treatment usually removes the white scale.
    Etching (from low pH/alkalinity/calcium) and scaling (from high pH/alkalinity/calcium) are uniform effects across the pool surface, unless affected by areas of greater or lesser pool plaster surface porosity. The etching process can create a uniform rough and pitted surface, but does not discolor the plaster. Calcium scale on the surface is also generally rough to the touch, white, and uniform (much like sandpaper). In time, scale or an etched surface will attract dirt and minerals, and discolor. Although stains, dirt, and scale deposits can generally be removed by sanding, acid washing or chelation, etching is permanent and can only be moderately mitigated by sanding the surface.
    Acid Start-ups – Swimming pools should never undergo the acid start-up process. Designed as a way to remove plaster dust without filtration, acid start-ups are too aggressive for fresh plaster and will etch the surface. Subjecting fresh plaster to water with a pH below 5 is not an appropriate substitute for doing things right in the first place. This just ages the pool plaster and will likely begin to show dirt and metal staining sooner than usual.
    Plaster Dust in New Pools – This is the bleeding (loss) of calcium from a new plaster surface that may be caused by improper plastering practices and/or as a result of filling too soon or with too soft (aggressive) tap water. This dust can harden into a surface calcification and trap dirt or metals, creating further discoloration. Dusting from new pool plaster is preventable by properly mixing, troweling, curing the surface in moderate temperatures and with sufficient humidity, waiting at least six hours before filling, and then ensuring the chemistry of the fill water is balanced before being used to fill the new plaster pool. When necessary, the fill water chemistry should be adjusted by adding sodium bicarbonate, acid, chelating or sequestering agents, etc. through a slurry tank as the pool fills. Although plaster dust can be removed by brushing and filtering, the damage from the calcium loss from the surface creates porosity and is permanent.
    Prevention is the key – proper plastering procedures, proper curing, and proper water balance result in a plaster surface that is both maintainable and aesthetically pleasing. Fixing errors after-the-fact is generally less than desirable, and some detrimental effects can only be remedied by replacing the plaster. Quality plaster that is maintained well and in CSI balance will generally last 20 years.
    Also see these posts: Being Blamed for Plaster Discolorations? Don't Get Hoodwinked
    ten-guidelines-for-quality-pool-plaster-t42957.html
    Re: Diagnosing Pool Plaster Problems
    Awesome information. Thanks!!!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    This is great information. My pool has a very rough surface, pretty sure this is due to calcium deposits. The previous owner had a SWG, it has been removed and I use liquid chlorine. In addition, the spill over spa has white residue on the spill over part and there are a few spots on the tile which are obvious calcium build ups. In addition, the pool has little moon craters throughout the ground. The low spots of the craters are orangish, guessing that's a mineral build up of some sort. There are two spots in the pool where it appears the plaster is down to the gunite (grey spots). These spots are about a quarter in size and both are where the floor starts curving into the wall.
    I think the pool could use a resurfacing.... but I don't want to dish out that much cash yet. I'm thinking of having an acid wash done and having the "bare spots" patched. The pool is rough on the wall and the floor, scraping up my kids. I just want it smooth enough to be comfortable until I can get it resurfaced. Would an Acid Wash and patching solve my issues for a year or two?
    Thanks
    pool products ~ swimming pool pumps
    "Live in the sunshine, swim the sea, drink the wild air." ~ Ralph Waldo Emerson
    Jul 2011
    799
    It does sound like your main problem is due to calcium scaling everywhere. So yes, an acid wash would probably work well in removing the uniformly rough and abrasive scale and allow you to add a few years to the life of the pool. Be sure to not over do the acid wash. Bu t you have to make sure it is calcium scale desposits and not an etched surface that is also rough. If it is that instead, then only sanding will make it smooth again.
    I am not sure about the craters or bare spots. Would need pictures to help diagnose. Those may be spalling or simple flaking of the plaster surface. My guess is that plaster patching would not work very well. Instead, I think heavy sanding of those areas would help to smooth those areas again. If you are right that the gunite has actually been exposed, then perhaps plaster patching would be the best option.
    Feb 2013
    California
    18
    I had my pool re-plastered (dark) in January of this year. Over the past month, white rough patches have formed over the shallow end of the pool (see photos). I brushed the pool as instructed, but could be a chemical problem. The plaster company did an initial chemical start up and I have had it maintained well. I called them and they are going to come look at it. What can be done? What would happen if I do nothing?
    20,000 gallon IG recently re-plastered (dark), Jandy 580 Cartridge, 1 3/4 pump, Polaris 360 sweep. The pool was originally built in 1984; February 2013 underwent significant renovation. In my third home with an in-ground pool.
    Stockton, California
    Jul 2011
    799
    It is difficult to determine for 100% certainty from the pictures, but there may two different issues involved with your plaster. If it is rough like sandpaper, then it is probably calcium scale that has formed. That would have to be either sanded or acid wash to remove quickly and effectively.
    The two streaks could be "scratches" from brushing, or from a mistake in troweling during plaster finishing.
    If the white speckled areas are smooth to the touch, then it could be caused by very aggressive water, or from improper plastering. If from improper plastering, the white speckled areas will probably get worse over time.
    It would help to know what type of chemical start-up the pool received by the company. Was it an acid start-up, or balanced? They should be able to provide you with some records on what they added and did.
    Do you know what the tap water readings are; pH, TA, CH?
    What are the pool water readings currently?
    Feb 2013
    California
    18
    It is rough like sandpaper and the two streaks developed almost overnight and believe they are not pool scratches. I know the pool company added a chemical for water hardness and muratic acid. I have been adding acid quite a bit to keep the PH at an appropriate level, but it raises up a lot too. I don't know what the tap water readings were and right now all chemicals are in the right range. This is my third new plaster start up over the years and this is the first time this has happened. The plaster company is going to look at it next week. I'll will have to wait and see what they say. More than likely it is calcium scale; What would happen if I just left it as is?
    Jul 2011
    799
    Scale is mainly a cosmetic issue, and can be left as is until you want to do something about it.
    But of course, the roughness wouldn't be nice to walk on or rub up against on the walls.
    Let me know what your plasterer says after he inspects the pool, but I suggest that you get a second opinion from a local and experienced pool "service" company. I have a feeling that there might be another issue involved with the plaster having white streaks and spotting.
    Feb 2013
    California
    18
    I'll let you know what they say. They are largest pool re-plasterer and the company most pool builders sub-contract for plaster in the greater Sacramento area. This is the second pool I have had them re-plaster. I do notice the trowel marks within the white area as well. And fortunately the roughness is no problem and it's isolated to just the bottom of the pool. Thanks for your responses.
    Feb 2013
    California
    18
    A plaster specialist from the plaster company looked at my pool today and determined it was calcium which bleached out of the plaster. My PH was high (8.0) when he checked it. I have been using the test strips which results in a lower read...I will toss them and get the drops. Anyway, he scrubbed the calcium spots and it comes off clean. The company will send a crew out next week to scrub the remainder of it out free of charge. My last pool was re-plastered by the same company with the same color plaster and this did not occur then. I hope it's just because of a high PH that brought this on; I will ensure it's under control from now on. Thanks again for your help and responses.
    Jul 2011
    799
    A high pH does not cause calcium to be "bleached" out of the plaster surface. The loss of color is a porosity issue, and is generally not caused by bad water chemisry. More likely, it is a workmanship and material additive issue.
    A high pH can cause calcium scale to deposit on top of the plaster surface, making it whiter. And generally, uniformly, not in streaks or large blotches.
    Simple sanding or an acid treatment can remove the white calcium scale to again expose the original color.
    Feb 2013
    California
    18
    I agree that it's bad workmanship. The company showed up yesterday and added 8 gallons of acid and will return in a few days to check it. The company employee alluded to a possible additive problem when mixing and applying the plaster because the scale is just on the bottom and not on the sides. He also indicated that it should come off without any scrubbing. We will see. I'll keep you posted.
    Feb 2013
    California
    18
    The pool plaster reps returned a few days after pouring 8 gallons of acid and added another 5. It appears the additional acid worked as the white scale is gone. I'm now raising my ALK in order to balance the PH. An acid wash with a total of 13 gallons was the cure.
    Quote Originally Posted by Barfo View Post
    I know this is a very old thread, but when they say acid wash...is that what that is? Pouring large amounts of acid into the pool? I thought it would be a drain of the pool and some sort of hose down with a diluted acid mix. What does dumping 13 gallons of acid into a pool do to the pool heater?
    Plaster In Ground, with Waterfall Spa. Raypak Heater, Nautilus DE Filter DNS48. Built about 2000.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,200
    Acid wash typically refers to draining the pool, spraying acid on the plaster, brushing it, rinsing it and refilling. There is also a no drain acid bath discussed here, The Zero Alkalinity Acid Treatment
    A heater should be bypassed if the PH will be below 7.2. Especially if it has a copper heat exchanger. PH below 7.2 will dissolve copper into the water.
