Thread: Numbers don't match up
    EDIT 5/22/07 TMQ I moved this to its own thread so you can get better answers
    I'm a newbie and I have been testing my own water. I usually take my water to the pool store to double check my results. I'm not here to bash and I'm glad that I have a pool store close to my house but I have to say that this past week their results were way off from mine.
    My numbers were as follows before I added chemicals:
    CL 1.5
    FC 0
    TA 90
    CH 260
    PH 7.8
    CYA 50
    Their numbers before I added chemicals:
    CL 0
    FC 0
    TA 70
    CH 210
    PH 7.2
    CYA 40
    The PS guy asked what color was my water before giving me the test results and I responded that it was crystal clear but I knew I was low on CL. After seeing that their test showed CL 0 I knew why he asked the question. My first thought was their numbers must be wrong but on the drive back home I started second guessing myself, maybe I was doing something wrong. I retested CL using the FAS-DPD method ( I used the OTO the first time) and got CL 2.0 ( using the 10ml sample the 3rd drop was light pink and 4th drop was clear). Since the first step in that test is to add the powder and water should turn red if FC is present and that is exactly what happened I new my tests were right. Imagine if I did not test my own water.
    I am glad to say that I did add Chlorine and my CL is at 4. But this proved to me that the Pool Store do make mistakes with their test, different employees have different results and their test might be setup to sell chemicals.
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    Mar 2007
    San Rafael, CA USA
    Depending on the container that is used to carry the pool water sample, it is possible for the chlorine level to drop over time. If there is any contamination in the container or if it is open to the air or if there is a lot of air in the container and shaking occurs, chlorine levels can drop. I've seen this happen when making my own measurements so can imagine it happening in the much longer time it takes to get a sample to a pool store. Now that said, the drop I have seen isn't very large and being careful will usually prevent such problems so in your case it's much more likely that the pool store simply got it wrong for whatever reason.
