Results 1 to 7 of 7
Thread: Hello from Redding, CA
    Hi all,
    I've been working on resurrecting an in-ground pool.
    A bit of history:
    From some permitting records it was installed originally in 1979. It's a kidney shaped and I'm guessing 25k gallons.
    We purchased the home+pool in 5/10 as a bank owned. The pool of course was opaque and difficult to judge its condition.
    The first order of business was to start the remodel of the house. In concert we started to determine condition of the pool.
    We immediately found out the pool was is VERY sad shape. The equipment (1.5 hp pump and undersized sand filter) appeared to be original equipment. We hot wired around the non-functional mechanical timer and were able to restart circulation.
    The county mosquito abatement office also paid a visit to ask if they could add some "guppies" to our "pond". I had to sigh and tell them that the frogs living in it should be sufficient until I can get it cleaned out.
    As it being completely opaque we started to "dredge" out the bottom. Trust me, "dredge" is an accurate term. We would spend about 2 days per week bringing up what seemed a "bottomless" amount of palm fronds/leafs and "goo" (it had gone septic from the smell). Of course every dredging operation would result in the water column going BLACK. Not "green" or "minty" or "cloudy", completely "BLACK".
    By the fall of '10 we started adding some liquid clorine and flock to get some clarity to what was left in the deep end. It was at this point we found: An 8x12 outdoor carpet and a metal baby's high chair (we started getting scared about what _else_ might be hidden in this "pit"). After extraction of those, we managed to get a fairly clear water column, but as winter approached, we placed a "tarp" cover to wait it out till spring.
    In the spring of '11 we replaced the ancient equipment with a pentair SVRS and a cartridge based filter. Used that to vacuum remaining debris (with almost hourly cleanings of cartridges). After many brushings and "shocks" we had a crystal clear pool! Of course, we had simply lit a time bomb due to relying upon "advice" from the LPS.
    After a year of a "nice" pool in '11, we left it open during the winter. It was also evident that the gunite plastering was deteriating.
    In the spring of '12 we had "green" water coluum and debris to remove. Got that cleaned via "shock" and vacuums. Everything was fine, of course .... until it wasn't.
    We started having abnormal chlorine consumption to the point of it being "never enough". The LPS would tell us "everything is fine, just add more tabs/bags of chlorine, it's normal".
    I left town for a week, and came back to a perfectly clear water coluum, with green algae covering every underwater surface.
    On the early morning of 8/12/12, I vacuumed the algae that I could, brushed the rest, and threw in my last pound of cal-hypo "super shock".
    FWIW, here's the numbers from the LPS on 8/12/12:
    FC: 5 (I had added a pound of cal-hypo 12 hours earlier)
    TC: 5
    Ph: 7.2
    TA: 110
    CA: 100
    CH:250
    Nitrates: 10
    On 7/15/12 we had these numbers from the LPS:
    FC: 5 (was also after adding some cal-hypo 6-8 hours earlier)
    Ph: 7.4
    TA: 120
    CYA: 60
    CH: 200
    Phoshpates:: 100
    Sadly, I did buy more "stuff" at the LPS on 8/12/12: 6 lbs of cal-hypo "super-shock", a quart of "copper algicide", and 25 lbs of "tabs".
    I finally decided to figure out this on my own and am happy I found this site. My Tf-100 is on order (I splurged and got the "stirrer" as well). My only test kit at the moment is the "Leslies OTO Deluxe" ...
    In the meantime, I'm adding the "pounds of super-shock" I have in inventory each evening and my "Leslies OTO" kit is registering _some_ chlorine each morning. I'll return the algicide, and either return or hold the tabs for future.
    Currently the water is a bit cloudy but clearing.
    1979 Inground gunite kidney shaped pool (20000 gal estimated). InteliFlo VS+SVRS, Hayward SwimClear cartridge filter.
    38,473
    Re: Hello from Redding, CA
    Welcome
    The first thing you are going to want to verify when you get your kit is the CYA level (well really everything, but CYA is critical). The test usually max out at 100ppm, so it could be well above that. When you get your kit, you can use a 50/50 mix of pool and tap water for the CYA test and then double the result.
    Note the recommended ranges are 30-50ppm for CYA ... so you are likely looking at a lot of water replacement to get that in range.
    Just want you to realize that as any chemicals you are currently adding, might just be pumped out this weekend if the CYA is indeed high and you decide to replace water.
    Definitely try to return the copper algaecide ... you do not want to add the metal to your water.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, curreyr
    Sounds like you have already read a lot of pool school. Good job on the test kit and speedstir...it will impress the neighbors
    Until you get you kit, you might want to just maintain ~ 5 ppm FC in your pool (you can use poolcalculator.com to calculate how much to put in each day). Once you get the kit, post your numbers.
    That's my plan ...
    Is using the "super shock powder" (label says 73% cal-hypo) going to be a problem? I still have 3 lbs ...
    Current crappy OTO test kit shows Ph at 7.2 and TC? at 5+.
    We have 9' of visibility, but we have also had it be more "clear" in the past.
    I'm suspecting that the recent algae kill (3 days ago) hasn't completely been filtered.
    The walls and floor have no sign of green and have been brushed daily.
    The water is also losing it's milky-ness daily since, but I do suspect another cartridge clean out is in my near future.
    38,473
    Your CH is still on the low side, so using the cal-hypo is fine.
    Add your pool and equipment details to you signature so we know if it is plaster/vinyl etc. Directions are in here:
    pool-school/read_before_you_post
    Yea, details are coming soon ...
    One question how do you know the volume of a kidney shaped pool that is roughly 16x32 and 3.5' shallow and 8.5' deep?
    Once I establish some balance, I figure I could dump a quantity of "soda ash" and from that back calculate the volume.
    38,473
    Just make your best guess to start (a very quick calc gave me 17,000 gallons, but very little thought went into it ... key is really estimating the average depth).
    Then as you use the poolcalculator to calculate dosing of chemicals, you will get a feel for if you estimate is high or low based on the actual result ... as you mentioned.
