Thread: WalMart 6% stronger then HTH 10% ???
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Memorial Day weekend Ace hardware had HTH 10% liquid chlorie on sale. Based on my guess of usage I bought enough to last through September and have stored it in the house.
    My Stenner pump is set and my chlorine level as been very consistent between 4.5 and 5.5 all summer. The Stenner runs several times during the day to keep the level consistent as opposed to letting it drop and hen adding a bunch to bring it up.
    I ran out of the HTH chlorine last week. I bought 6% bleach from Walmart and a put it in the tank. The last few days my chlorine has been 7.0 to 7.5........ It should be lower, not higher?
    Based on running out now instead of my estimated late september and the jump with the Walmart bleach I'm guessing the HTH from Ace was not really 10%; but it is possible that the Walmart stuff is strong instead. What do you think?
    PS: the HTH had a current date code on it, was not left over from last year.
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Butterfly's Avatar
    South Carolina
    10,045
    Re: WalMart 6% stronger then HTH 10% ???
    My guess is that the HTH 10% degraded. The higher the %, the faster the rate of loss.
    Also, sometime during its lifetime, it might have been stored in conditions that were not near as good as inside WallyWorld in the AC
    You're done SLAMing when:
    38,242
    My guess is a little of both. The 10% may have dropped depending on how and how long it was at Ace. The Walmart gets turned over pretty quickly so it may have a higher strength (I think 6% is meant to be the minimum).
