Results 1 to 7 of 7
Thread: Intex KC Sand Filter 14"
    NY
    27
    Hi everybody! You guys do a wonderful service in this site.
    I would like to ask you some questions. My pool specs is on my signature. (Intex Krystal Clear Sand Filter pump 14" SF15110).
    Q1: The pressure gauge on my sand filter goes to yellow when running the filter and drops to green when I turn it off. It used to be on the line between the green and the yellow. Is that normal?
    Q2: The reason I said the color is bcause I cannot read the real numbers because of condensation on the pressure gauge. Is that normal?
    Q3: When should I backwash? What is the reason for it?
    Q4: What is a pressure numbers that I should expect? Does it depend on the pump or there is a standard?
    Q5: Do I need to install a rose/clamped on the Drain outlet only when backwashing? Does it have to be covered for filtering? I saw some videos and it seems that you have to remove the hose and cover.
    Thanks for your help.
    Marcelo
    Intex above ground Rect UltraFrame 12x24x52, 8500gal. Krystal Clear Sand Filter Pump 14". Intex SWG.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex KC Sand Filter 14"
    Welcome to tfp, marolir
    Quote Originally Posted by marolir
    Your gauge is likely going bad. I would replace it with one that has bi gpressure numbers on it. Get one that goes from 0 to 30 psi.
    When your pressure goes up 25% from the "clean" pressure. Backwashing removes the debris that the filter has caught. Eventually, if you do not backwash your flow rate will diminish.
    Depends entirely on your setup...but 8-12 psi clean is not uncommon (I think it is a bit lower than that on the intex).
    You can leave the hose on or take it off...doesn't matter. It does not have to be covered when filtering.
    NY
    27
    Hi Linen, thank you for your help.
    The gauge is the original that come with the pump from Intex, I am going to call and ask for a replacement.
    Today I installed the SWG. Now, I have the filter and the SWG on my backyard. Should these be protected from the rain,etc...? Or, just leave next to the pool with no protection?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If they won't replace it, just get a cheapo from a home center/hardware store.
    Doesn't have to be, they are designed to handle the elements.
    NY
    27
    Linen,
    Is the vinyl affected by sunscreens?? Is there anything i can do? Everybody uses sun protection today!
    Apr 2012
    SW Ohio
    456
    you may notice a oily coating on top of the water from the sunscreen and as long as your pool is properly balanced it should be taken care of and the sand filter will catch it you might need to leave the pump run a couple extra hours, atleast that is my experience.....Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Apr 2012
    SW Ohio
    456
    i use a magic eraser and clean the liner at the water level and it takes care of it nicely.....Mike
