Thread: hayward c3030
    hayward c3030
    hi i have a hayward ecostar pump and hayward c3030 cartridge filter brand new, we just had our liner replaced, added 3 loads of water, when I run my filter at 1000 rpm the pressure gauge on my filter did not go up, is this normal? Also I have a cmp in line pool chlorinator, am I running the pool pump fast enough for it to work? I do not see the flow meter moving but i could hear water inside. Thank you.
    Intex above ground Rect UltraFrame 12x24x52, 8500gal. Krystal Clear Sand Filter Pump 14". Intex SWG.
    38,260
    Re: hayward c3030
    Not surprising. Low speed (1800rpm) on my 2 speed barely gets my gauge to budge and barely seems to open the check valves.
    While 1000 rpm might be an efficient speed to run, out may not be adequate for skimming and cleaning purposes.
    I am not sure how effectively the chlorine canisters work on low speeds. Although we also generally do not recommend using them for fear of rising stabilizer levels.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Re: hayward c3030
    hello sir, does this mean it is not filtering my pool, I'm sorry for this question I am new to this, than you for taking time to answer.
    38,260
    Re: hayward c3030
    If you feel water returning to the pool, then it is passing through the filter and being filtered.
    Do you have a skimmer? Sometimes the surface skimming does not work too well on low speeds.
    Re: hayward c3030
    hi water is returning to my pool, I did increase my speed also. Thanks again
