Thread: Should I Add Borates Now
    I had a very good summer using the BBB method. I was lucky enough to find this website and start my new pool using BBB from the beginning. I think I'm ready to take the step to add borates but there is only about a month of swimming season left. Should I wait and do it when I open the pool next year?
    Todays numbers
    FC 7.5
    CC 0
    PH 7.3
    TA 110
    CYA 40
    Thanks Jim
    17500 gallon Sharkline Morada PUR RTR 18X40 54 tall, 1.5 Hayward cartridge filter,
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Should I Add Borates Now
    You can add borates anytime, but if you drain for the winter I would wait. When you decide to do it, make sure you get your TA down to 70-80 ppm before doing it.
    Jul 2009
    Olney, MD
    218
    Another benefit to waiting is that your borate test strips won't be opened and sit around for 9 months after you use just one strip for this last month. Order some in April and take your time over the winter stocking up in borax (if that is the method you choose).
    Disclaimer: I have used borates in the past, but not for the last two years since I have infants in the pool regularly. When I did use borates, the water clarity was superb and the pH didn't need adjustments for two week spans.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
