Thread: SWG: all lights were out and no display
    Recently replaced the current delimiter and all was fine. Noticed pool was showing some alge. Went out to check the SWG and found all lights were out and no display. Fuse looks good and transformer runs warm/hot. Yellow wire that runs to fuse connection looks a little burned but appears OK. Back of board looks fine (no discoloration). Odd thing is when I removed the cell cord from the board and put back in, the board came to life and worked fine. Came back about an hour later and found no lights or display again. Leads me to believe I have a short somewhere and the cord in/out excercise just moved something around. Don't think it is the delimiter again as I had some lights/power when that originally went out. At this point I am at a loss and am thinking I may have to just go with a whole new board. Fearful I will get a new board and still not lights. I would be grateful for any help or suggestions.
    Re: SWG: all lights were out and no display
    Hi if you are going to get a new one Target has an Intex buff beigh SWG on sale for $99.!!!! Don't know how good it is. Cheep enough to try it out.
    Temporary above ground, 4500 gal,
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by ActJax
    Clean the cord contacts and then reseat it. Sometimes it takes a smack with your palm.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
