Thread: I finally got my water balanced
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Every since I joined TFP I have been obsessive about my water quality, clarity and chemical balance. It always seems that some minor thing is slightly out of perfect balance....the TA is just a bit high...the CYA is low, or high...I've got .5ppm CC...always something. But yesterday for the very first time I checked the pool and everything was perfect....(well the CH is still high. But short of RO treatment of my fill water, there is no cure for that one in Tucson).
    Here are the numbers:
    FC 3.5
    CC 0
    TC 3.5
    pH 7.5
    TA 60
    CH 700 (fill water is in the 300+ range)
    CYA 80
    Salt 3700
    Borate 50
    Water is crystal clear and sparkles like diamonds. And this is with the SWG on 17% with six hours per day of run time.
    Woo Hoo, now to keep it this perfectly balanced.
    chiefwej
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: I finally got my water balanced
    Nice job cheifwej I feel for you folks having to deal with the high calcium hardness levels
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
