Results 1 to 13 of 13
Thread: anyone in NJ leave thier metal frame pool up in the winter
    I know this is talked about alot, but I am nervous about having alot of snow on the cover and
    the metal legs collapsing. The liner should be fine, I put a new 25mil pool liner inside the intex liner last week. I just don't want the have the pool collapse when it's cold and have water all over the
    street or in my neighbors yard. The pool is at the very far corner of my yard, very far from my house, and about 15 feet from my neighbors house. Last year the winter was mild, the year before we got like 12-14 inches. Can anyone calm my fears? Are those metal legs strong, it's no the ultra, just the original metal legs.
    Vinyl 18x36 Single Roman End
    ~26,000 Gallons
    Goldline SWG T-15 Cell
    Sand Filtration
    Pool Tool Zinc Anode
    LaMotte Color-Q Pro 11 Test Kit
    Apr 2012
    SW Ohio
    456
    Re: anyone in NJ leave thier metal frame pool up in the wint
    This statement is just my opinion I would think that a cover on the pool such as your would be worse than having no cover. With that being said when snow and ice accumulate on top of the cover it puts a lot of stress on the legs from all the weight pushing down on the cover and would make the bottom of the legs kick out. Now without a cover it would be like just having a full pool all the weight is pushing straight down.I would cover it until after all the leaves are down then take it off that is what I am going to do with mine this winter......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    DaneCE's Avatar
    Jul 2011
    VA
    279
    I agree with leaving the cover off as being safer/less stress if it fills with ice/snow. Last year I "closed" my AGP only because my pump was dieing and wanted to wait until Spring to buy a new pump although the warm Winter would have been a breeze to get through. One year I tried to cover my pool and it was a big failure so never again. This year I will be keeping it open and program pumping intervals when the temp drops below freezing. I don't have a large amount of leaves coming into my pool so that's a big help. I like the ability to filter year-round keeping the water clean so I have no extra work to do later. I live in SE VA.
    I wonder if I can put some type of mesh material over it to keep the the debris out, but it allows the snow to go through. I don't have a problem with leaves. Should I drain any water out?
    Should I use all the closing chemicals as normal just no cover?
    ~26,000 Gallons
    Sand Filtration
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    A person down the road from me left their pro series up last year, empty, and it all caved in. I can't believe they are using it this year, one of the post is bent at a 45 degree angle. They obviously didn't know to leave some water in it. I wish I could get a pic of it, without looking like a weirdo, lol.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Quote Originally Posted by amd250
    Have you read the winterizing section in Pool School ? pool-school/winterizing%20and%20closing%20your%20above%20group%20pool
    You can buy mesh pool tarps that let the water through and block debris. I've never used one but I fear snow would build up and be no different than a solid cover.
    So I will buy a cheap cover keep it on until the snow starts falling, then take it off once the snow starts. I have a a 25mil reg pool liner inside the intex liner which is working great. So it's pretty durable so when the water freezes it will be ok. Can the water in a pool really freeze totally solid? There should be no worry of the ice bulging out the liner and moving the legs?
    ~26,000 Gallons
    Sand Filtration
    Apr 2012
    SW Ohio
    456
    Water will expand up not out because of resistance usually and read the post that DaneCE posted that will cover everything........Mike
    I'll be leaving my ultra frame up this winter and I'll be covering it. Not at all worried about snow "bending" the legs. Given the "D" shape of the tubing, it's A LOT stronger than you think.
    Bboran
    2000gallon intex ag, 530gph cartridge filter,
    Apr 2012
    SW Ohio
    456
    bluefish it has nothing to do with the strenght of the legs the legs wil want to kick out because of the weight of the snow and ice accumulating on the cover and pressing downward towards the center of the pool and if you have the cover tied to the top rail or anchored to the ground in some fashion or worse tied to the rope around the bottom of the legs what s gonna happen when you get 2 or 3 tons of snow and ice on top of that cover? the best you could hope for would be for the cover to rip apart.....jmo.....Mike
    I Haas the same question. I live in CT and have a intex metal frame 15x42 pool and I would like to leave it up. Has anybody used or heard of secur net. Here is the link http://www.h2orec.com/secur-net.php?id=5
    After reading the posts and talking to a few people I know, I am going to buy a cover during the fall until the snow starts, then i will have no cover until the snow season is over. Then deal with the pool after that. I am thinking of putting Chlorine in the pool like once a every few weeks just to keep the water from going green. Not sure if I need to do that.
    ~26,000 Gallons
    Sand Filtration
    Well I am going to leave my intex pool with 25mil liner inside up all winter too. Been reading up on winterizing and finding a cover also on here. I was thinking about getting a solid cover and also getting a couple of air pillows to keep the cover from sinking down. That way the snow and debri would not have a way to build up (but still might). Other thought is to by the mech cover with the air pillows. Might be a flip of a coin and try it out and post the results next year.
