Thread: Mustard Algae?
    Mustard Algae?
    Hello all. I am new here and an owner of a 15'x48'' intex ultraframe pool. We've had no problems all summer until the other day I noticed some yellowish/orange/brown stuff accumulating around the edges of the pool bottom. I assumed it was algae (mustard algae b/c of the color?) so I shocked the pool last night, scrubbed with a brush, and added algaecide this morning. The algaecide I bought was Aquachem 50%. I noticed, after I added it of course, that is says "kills GREEN algae". Should I purchase their Algaecide PLUS which says it kills green, mustard, and black algae? Can I add it right away or should I wait? Thanks!
    In-ground 18x36 concrete pool
    Built: Spring 2007
    Sand Filter
    Salt Water Generator (T-Cell 15)
    Goldline Aqua Plus Control
    22,553
    Re: Mustard Algae?
    Welcome to TFP.
    If you'll read around here a little, you'll soon learn that algaecide is neither needed or wanted. I'd take the stuff that you haven't opened back.
    You most likely don't have mustard algae. Unless it's growing on the shaded side of the pool on the walls it's just green algae.
    Do you have a set of test results you can post for us? And how you got them.
    pH
    FC
    CC
    TA
    CH
    CYA
    Re: Mustard Algae?
    pH is 7.2
    FC is about 5
    TA is 100
    I know I should get a bigger test kit for the rest, but time just got away from me. I added stabilizer when we put the pool up according to the directions and I've been able to keep the chlorine level fine with floater tablets and occasional shock.
    I'm glad to hear that its just green algae. I didn't know it could be orangy.
    Here's my next question/dilemma with the intex pool. How do I get rid of the DEAD algae once its killed? The vacuum I use is the kind that hooks up to your garden hose with a bag. Its been doing a great job all summer for the big debris. I'm guessing the dead algae is just going to go right through the mesh bag. Do you think if I just keep brushing several times a day and stir it all up the filter will take care of it eventually?
    Built: Spring 2007
    Sand Filter
    30,432
    Re: Mustard Algae?
    Probably. It'll take some time. You should probably test for CYA just to find out where your FC needs to be.
    Re: Mustard Algae?
    What about a clarifier? Anyone have experience with these?
    Built: Spring 2007
    Sand Filter
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Mustard Algae?
    we rarely recommend use of a clarifier...they tend to cause more issues (foaming) than benefit.
