Results 1 to 9 of 9
Thread: bees have invaded my pool
    Jul 2011
    phoenix
    133
    over the last couple weeks we have have had a growing number of bees clinging to to the water level (rolled pebble edge). My house backs up to a canal and then its just state land (desert mountains). I have been working with the company in charge of the canal and they hired a bee person to take a look and determined there must be multiple hives at the mountain behind my house (about 3 miles away).
    Has anyone ever dealt with bees or have any suggestions on how to handle this?
    We have been unable to use our pool for the last 4 weeks and with temps at 110-115 now I need these things gone or to go find a new water source (don't know why they are not getting water from the canal).
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    Mar 2012
    Amarillo, Texas
    341
    Re: bees have invaded my pool
    Holy cow. I don't know how to fix that but I'd be scared to death.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Iciee
    Euck! We have some wasps that decided to make our pool their water source but I found them and "persuaded them" to stop - living that is...
    Could you try setting up a water source like a bird bath that isn't chlorinated near the pool and see if they migrate to it. Maybe run the pool up to MA shock to discourage them a little? Can you spray a bug repellant on the rim of the pool and lower your water a little?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Running a fountain from one of your returns aimed that direction may discourage them from getting their water there. Be sure and set up a small plastic kiddie pool as far from your pool as you can to give them a fresh water source.
    Love TFP? Become a
    TFP Supporter!
    Jul 2011
    phoenix
    133
    read somewhere that they are attracted to the chlorine in the pool So far I bought some plastic painters tarp and put a pool noodle in there letting it hang over the edge. This kept the bees from going there but the just moved over to the non covered area. Might change my pool to run during the day and see if the water movement from the waterfall/ and cleaner may keep them off if not will have to buy a lot more noodles and platic
    Circupool SI45+ swg
    Jul 2009
    Houston, Texas
    9,396
    Here is some information from an older thread. Honey bees.
    Love TFP? Become a
    TFP Supporter!
    Apr 2009
    South Texas
    177
    I have a pool fool of wasps. Very difficult to even get in or out of the pool with at least 20 on the ladder. Plus all the ones floating on the water. Unfortunately only about 1 a day ends up in skimmer. I have sprayed all around the house and garage and barns but I live on 10 acres in the country and they could be anywhere. I'll be watching this thread for suggestions. A small pool won't work because the dogs will just drink it or splash it empty while playing. Going to try borates but have to get TA down from 150 first. Hopefully someone will have other suggestions as well. Thank you!
    Just bought a new house in the country, no pool yet. :(
    Hot tub..500 gals..bromine
    TF100 test kit and speedstir
    Nov 2010
    Calera, Al
    271
    Have you tried adding borates to your water?
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Jul 2011
    phoenix
    133
    I have not tried borates yet but I think that may be the next step. Forgot to mention the wife is allergic to more things then I care to count and we are not sure if a bee is one of them (never been stung by one) but we don't want to find out. Also thought about a super soaker with some water and dish soap to kill the bees but I think i would just get a new batch every day
    Circupool SI45+ swg
