Thread: Buried AGP pool in NTx
    Jul 2012
    Collin Co Texas
    4
    We purchased a 21' round Doughboy pool from Crown last month and are finally having it installed tomorrow. I've read posts on here from others in my area who have buried an AGP and I am optimistic that we will have a good experience.
    The ONLY thing I have every done is SWIM in a pool. I have no idea where to start with actually taking care of a pool and since tomorrow is THE day, I guess I need a crash course.
    What did we purchase:
    21' Autumn Breeze
    SD60 200# sand filter
    Polaris 65 automatic pool cleaner
    Hard bottom
    Timer
    and a few other things...I guess I'll be doing my best to keep my head above water.
    21ft Autumn Breeze AGP, Buried 2', Hard Bottom, SD60 Filter, Polaris 65 Cleaner, 1HP Pump, Upgraded Skimmer, Installed August 14,2012
    Aug 2008
    Fredericksburg, VA
    51
    Re: Buried AGP pool in NTx
    Welcome to TFP! Your first stop (after ordering your TF100 test kit!) is the Pool School located here on this site. Read it, then read it again.
    You can order the TF100 kit here: http://tftestkits.net/splash-page.html
    20,000 gal. free-form plaster on concrete
    Triton DE filter, 1.5HP pump
    Aquabot Elite pool cleaner
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Pool school, a good test kit (not strips based) and the pool calculator is all you need, asap!!
    This will give you:
    - the knowledge on what to do and why
    - the kit to perform the tests
    - the website that gives you the level of treatment based on your test results
    Maintaining a pool is not hard if you put in a bit of time to learn and get a good test kit, it's not something you need to pay someone else to do. The first few tests may be a challenge but it's all repetition, after awhile you'll have it all committed to memory and you'll have low cost crystal clear water!
    Post some pics when its up.
