Results 1 to 9 of 9
Thread: 1" pucks -- how much Chlorine and CYA? and other puck info
    Jul 2012
    San Mateo, California
    14
    Hello,
    Pool is running clear, but I'm getting tired of adding bleach every other day. I want to raise my CYA. (my readings below)
    I have a small pool, and would like to try 1" pucks.
    How much FC and CYA can I expect from 1" pucks? (as in ppm per 10,000 gal per puck)
    Is their composition and chemical release rate the same as 3" pucks?
    Thanks!
    pH 7.8
    FC 6.0
    CC 0.5
    TA 70
    CalHard CH 250
    CYA < 20
    2,600 gallon outdoor pool/spa, rectangular 15' x 8' x 3.5'Deep, IG plaster (age 25+years)
    Yosemite Hetch Hetchy tap water, nice and soft.
    DE 60sqft 120 gpm Hayward, Filter Pump 2.0 hp with 10.5 SF, Jet Pump 2.0 hp with 1.0 SF, Rheem 400K BTU/hr
    BBB starting Aug 2012.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,093
    Re: 1" pucks -- how much Chlorine and CYA? and other puck in
    They are like 3" tablets with a weight of 0.5oz of trichlor. For 10k water each will add .3fc and .2cya.
    For 2600 gallons they add 1.3fc and .8cya.
    Jul 2012
    14
    Thanks!
    You said "For 10k water each will add .3fc and .2cya. "
    Is that for 3 inch puck or 1 inch puck?
    Jul 2011
    Eastern Ohio
    7,093
    For a 1" puck.
    Jul 2012
    14
    Thank you!
    My summary for anyone researching this post in the future:
    Pucks can come in different sizes (like 1 " or 3 " diameter) and different composition (like Trichlor or CalHypo or other). Be sure to read the package.
    In the pool calculator at poolcalculator.com, you can find the "Effects of Adding Chemicals" by typing in how many oz your puck is, and what it's main chemical is. Type in your pool water volume at the top, and it will caluclate the amount of FC, CYA, etc will result from your puck.
    For my 1" TriChlor puck, which weighs about 0.5 oz. it will add 0.3 FC and 0.2 CYA into a 10,000 gallon pool.
    30,421
    Good summation. The Cal Hypo pucks you may see around (on uninformed websites) are really not designed for pool use and the forum discourages the use of them. They CANNOT be used in a tri-chlor feeder.
    Jul 2012
    14
    Thanks, Dave! I'm enjoying my T-100 kit. Very well organized.
    Karen
    May 2012
    Allentown, PA
    219
    Just wondering how much FC and CYA 3" pucks add to a 20,000 gallon pool? Just trying to bring my cya up from 30. Am I losing CYA from rain water and backwashing through the season? What other effects do the pucks have on the balance of the water? Thanks DW6
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Jul 2011
    Eastern Ohio
    7,093
    3" pucks vary often in how many oz of trichlor they are. Most are either 7 or 8 oz....but the weight of your pucks will alter these numbers slightly. In The swim pucks are 7oz while Leslies weight 8oz.
    FC 2.4
    CYA 1.5
    Ph will be lowered 0.13
